V70 II dashboard doesn't show speed, rpm etc.
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
s3bi wrote: 14 Jun 2020, 20:27 Does anyone know if I can just pull them off?
In your case there are a t least 3 ways:
1. You can try to fix it yourself if you have soldering experience.
2. You can try to find some service which can fix it, which specialized on it.
3. You can buy same DIM from some junkyard. Most likely, DIM from 2004MY will work on your car without some reprogramming stuff...(in worst case it have to be reprogrammed)
s3bi
Year and Model: 850, 2.4L 10V, 1996
Has thanked: 18 times
Post by s3bi »
yagger wrote: 15 Jun 2020, 10:48
I would do that if I would get it apart mechanically. I already had to glue three things which I broke after removing the dashboard. Hence I don't want to pull the delicate needles out and break the mechanism.
jonesg wrote: 14 Jun 2020, 22:45 Thats the instrument panel, I think Oragex was talking about the module that resides near your knees when you sit behind the wheel.
you are looking for this,
I tried that but I can't unlock the CEM like he does at 3m45s.
Reaching behind it and pushing it forward doesn't work. I've watched the video several times now but either I'm doing it wrong, the mechanism is different, or I'm not pushing hard enough because I fear to break something.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
They always make it look easy in the videos, its not real world, they already removed it and put it back before turning on the camera.
In reality it takes a lot of fighting, band aids and cursing.
You disconnected the battery right?
if not, do so.
otherwise, lie on your back with your head on the brake pedal to get a better view.
s3bi
Post by s3bi »
jonesg wrote: 17 Jun 2020, 20:54 They always make it look easy in the videos, its not real world, they already removed it and put it back before turning on the camera.
if not, do so.
I always disconnect the battery when I'm working on electrical parts of the car, shorting things out sometimes damages more than the fuse…
I got it out now, there's an additional clip on the left which the video doesn't show. I found it with an endoscope camera. Seems to be a bit different, also the paneling was different to remove than in the video.
jonesg
Post by jonesg »
They're odd like that, you can't work on certain parts of the car without a camera phone unless you're familiar with the puzzle.
Try reading the engine serial number from the back of the engine block without a camera , not gonna happen.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The 2004-up CEM is pretty bad to remove indeed. Don't forget to seal properly under the cowl if you find where the water is leaking
s3bi
Post by s3bi »
I can't see any traces of water up to this point. I've removed the relays and the shunts.
Should I remove the CEM further from the housing anyway? The connector also doesn't want to come off like in the video after removing the screw…
s3bi
Post by s3bi »
oragex wrote: 21 Jun 2020, 15:12 Don't forget to seal properly under the cowl if you find where the water is leaking
Doesn't look like there was any water leaking at all. No signs of corrosion, I also looked inside the holes with a flashlight and the PCB also doesn't show any signs of something that could be wrong. I think I just reassemble it all now and hope it was a loose connector which makes better contact now after I plugged it back in.
What held me up was the screw of the connector which didn't want to come out like in the video, so I had to carefully slip it over when removing the connector.
jonesg
Post by jonesg »
the xemodex website has a flowchart to determine the symptoms, I would try to follow that.
