2002 V70 2.4T When does Radiator Cooling Fan Activate?
Has thanked: 1611 times
Been thanked: 4074 times
Use the wiring diagram to feed the fan 12 VDC directly to test
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
KidsV70 wrote: 11 Jul 2020, 13:32 Okay, and some more diagnosis. Used VIDA to command the fan on. No fan function in any of the 3 speeds (25%, 50%, 100%).. I did some careful poking with an old windshield wiper blade, and the motor is tight. I can turn the fan blades but not as easily as I'd expect. I'm thinking deceased fan motor at this point. Thoughts?
mine spins easily.
KidsV70
Year and Model: 2002 V70
Has thanked: 12 times
Been thanked: 4 times
Post by KidsV70 »
Thanks Abscate! That was just what I did yesterday.
Here's what I found:
--- 12.68v at the fan connector, so it is getting power
--- IF I apply battery voltage to the fan turns it on, though it seems slow to get to speed.
---- I grounded the fan controller wire and fan did NOT turn on. According to the Internet, which is never wrong :-D :-D Grounding the
controller should be the equavalent of a full-power ON signal to the fan, right?
Anybody know if #3 up there is in fact correct? I know the EEC-IV computer activates its solenoids, that way.
Thanks,
Bert
jonesg
Post by jonesg »
did you unplug the fan or back probe,?
It could just be green corrosion in the socket .
KidsV70 wrote: 12 Jul 2020, 09:14 Thanks Abscate! That was just what I did yesterday.
Thanks,
Bert
Key on and grounding each of the two signals on the controller should turn them on, but you need the plug pulled to do this and the reconnect power somehow, if it’s a single plug.
Fan should come up to speed in a second or two.
Tyc fan with controller is about $200. SKU: TYC-30680547
Junkyard alternative about $35 plus trip, 2001 2002 2003 part
KidsV70
Post by KidsV70 »
jonesg wrote: 12 Jul 2020, 10:58 did you unplug the fan or back probe,?
Good point but I unplugged. Both connectors are clean as can be.
Thanks though!! :)
KidsV70
Post by KidsV70 »
************************stuff snipped for brevity***************************************
Thanks,
Bert
Thanks! Conveniently it's one of the 2-plug fans instead of the single plug, so power plus grounding is easy
One question- why key on? The power plug has 12v when the key is off. I ran out and tested it key on, and then started wondering. :oops: :lol:
BTW, the TYC fan is ~$116 at Rockauto.
FCP Euro is awesome for finding what years fit what. I'm surprised that they want so much more than Rock for the same fan. Usually their prices are more competitive.
My thought, FWIW is to get a new one. This is my daughter's car (thus the screen name) and she's going to take it to college at some point.Assuming something catastrophic doesn't happen to it first.At which point it is going to be a collection of excellent finds in the junkyard, or on here, sadly.
Best,
Bert
FCP one comes with controller, probably the difference
For the unplugged fan, correct, the ignition key position doesn’t matter
KidsV70
Post by KidsV70 »
abscate wrote: 13 Jul 2020, 14:15 FCP one comes with controller, probably the difference
I hope it does. If not, I'm going to be ticked, because it clearly states in the description that it does come with controller. I'll let you know Thurs or Fri, when it arrives.
