Heater Core blew during full throttle. Headgasket leaky?
- Has thanked: 1611 times
- Been thanked: 4075 times
Dampness in the turbo intake is normal, especially if you haven’t been cleaning the PTC every 30k miles per the maintenance schedule
SweetSmellOfFailure
- Year and Model: 1994 850 T5
- Has thanked: 3 times
Yeah, I have to clean that, also noticed that the PCV hardpipe going to the PTC 'valve' was broken when I disconnected the heater core, so that probably contributes to it.
As for replacement heater cores, are spectra brand ones okay?
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
The "Swedish Auto Parts" unit from eBay has a decent reputation. It's like $40. Supposedly addresses the weak end caps in the design.
When my heater core popped under exactly the same circumstances - high revs, steam from the dashboard, bypassed it to get home - I used the Swedish Auto Parts unit for a few years, then swapped in a Behr OEM core when I had the coolant drained for other reasons. The original lasted 15 years and 250,000 miles, which I figured was a good track record. $40 or so more than the eBay piece.
bronco
- Year and Model: 1998 V70
- Has thanked: 49 times
- Been thanked: 24 times
many engines have issues with overpressure in coolant. As pointed out , the waterpump is driven at some ratio to engine speed high engine RPM equals high water pump RPM .
Back in the day when i was drag racing ford small block V8 powered mustangs about 6000 RPM was the limit for heater core safety .
If you ran underdrive pulleys you could go higher . The small block ford V8 had a wet intake manifold and on carburetor engines the heater core was plumbed into the intake . We experimented with flow restrictors and amusingly I once put the restrictor on the wrong side . Instead of restricting water flow *INTO* the heater core I mistakenly restricted it on the hose out
When I say restrict its a fancy way of saying I put a 3/8 drive deep socket inside the heater hose
Fuel injected cars though have a lot of random silly coolant lines going every which way and any of those can easily let go at high RPM if they are 20 years old . Turbo water hoses for instance
especially if oil has been dripping down onto it from a blown cam seal or summat
- 11 Replies
- 9919 Views
- 5107 Views
- 2696 Views
Last post by Legofan
- 1931 Views
Last post by fisker247
- 32 Replies
- 17980 Views
Last post by sleddriver
