Solved nasty brake squeal on Grunhilde. Pulled left front, pulled pads, little but of cleanup on rotors, chamfered pad edges, lube caliper slides
Pulled right rear, pulled drum. Inboard brake pad stuck in rusty caliper. Freed up and lubed, reinstalled, adjusted parking brake.
Zip tied parking brake cables to trailingarms.
Investigated starting cranking problem. Getting 12 Volts to 86 on starter relay but no cranking. No ground to 85. Possible fault in relay terminal 87 to starter motor solenoid pin. Car does start remote terminal
Update-corrosion on connection at starter. Make break relieved condition
12-15 new right Lca Lemforder
UNG rear rotors , adjusted parking brake
New Volvo right rear pads, need left caliper and hard brake line
viewtopic.php?f=1&t=92075&p=589741#p589741
3 hours
1998 v70 NA Grunhilde M56 517772 421 green
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
- Has thanked: 1502 times
- Been thanked: 3817 times
Re: 1998 v70 NA Grunhilde M56 517772 421 green
UBG left rear caliper , made up new line from CuNiform line and Neiko bubble flare tool
New rear brake pads and hardware
Replace seeping lower rad hose
Chassis break -1998 on hose
viewtopic.php?f=1&p=592785#p592785
abscate wrote: ↑25 Jan 2022, 04:02 UBG left rear caliper , made up new line from CuNiform line and Neiko bubble flare tool
Finished rad hose with closed clamps.
Installed air guide with zip ties.
Installed dash cover under steering wheel
Need stiffener plate under muffler from Jane Bond
Installed stiffener plate
R/R left front wheel bearing , FAG
Installed wheel seal
3 hours
3 hours
17 May, hard shifting. Relived with engine off. Clutch release issue. Tried bleeding, master cylinder pooped out, replaced.
Still have had shifting’
viewtopic.php?p=600952#p600952
Clutch bleeding
viewtopic.php?p=616767#p616767
