Brake caliper binding/sticking after hard braking
Has thanked: 1611 times
Been thanked: 4074 times
Give them 28 seconds of heat with propane and they will come free just fine. Very high quality on the masters on this car.
I’ve got a used one I think if you want to save half the bucks, at least.
I sold a older one but I think I have a like new one off my first parts 1999
Milehighv70xc2
Year and Model: '99 S70 T5 5spd
Post by Milehighv70xc2 »
Update--
I dont need to be driving the car to get it to stick and it doesnt matter if the brakes are hot or cold.
Just lightly pressing and holding the pedal down will cause it to stick. Dont have to pump them to get it to stick. The pedal gets more firm when it sticks as well. Car doesnt need to be to on or running to stick.
Once it is stuck, with the car on or off, I can watch the fluid very very very slowly return and raise the level in the reservoir as the calipers becomes unstuck. Takes a minute or two.
Removed abs fuse, no different.
Unplugged abs module connector, no difference.
The fluid flows out to each caliper the same at all four corners. Confirmed from bleeding the brakes. Its just the fluid is not returning from the right front. Seems something in the abs block or master cylinder is clogged. The fact the fluid flows out just fine is kind of confusing.
Still sound like a master cylinder?
Abscate- thanks for the offer on the MC. I might take you up on it. I will PM you if I decide to go that route
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 120 times
Been thanked: 189 times
Post by pgill »
Don forget to change the brake hoses.
When the hoses get old they can act as a check valve.
pgill
Post by pgill »
Also you mentioned that you lubed the slide pins.
Did you use a Silicone based grease?
If you use a petroleum based grease then the bushings can swell and cause brake binding.
I use CRC Silaramic Grease
It a silicone grease with ceramic particles.
It works really well.
Good luck
Paul
PS If a new brake hose and Silaramic grease don't work then I would replace the master cylinder.
pgill
Post by pgill »
If you use a wheel bearing grease then you will need to replace the bushings on the caliper when you switch to Silaramic (or something similar)
Milehighv70xc2
Grease is a Bosch branded synthetic. Not sure if it is silicone. Came with the Bosch brake pads I put on another car.
New brake line
Update-- I was able to get it to lock up with the car off. I applied pressure to the pedal for about 20sec and it locked up. It released within 20sec. Unlike when it happens with the car running and it takes a few minutes.
I unplugged the abs module connector hoping that is was a bad connection with one of the pistons in the abs block, Didn't change the problem at all. Seems to be a mechanical problem.
Sounds like a master cylinder is next.
Thanks everyone for your replies. I wont be able to work on It until monday. I will update the post whenever I fix the problem.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Sounds like the ABS? Not the electronic part but the "block" with the motor on it.
BMW 540i 2002
S70 Base 2000
Milehighv70xc2
Kallekula- I would agree since all for brake lines run separately from there. From the master the fronts run together and the rear run together to the abs block. I have been thinking something is clogged in the return port. I dont know very much about how that all works but from my research it seem pretty straight forward.
The master is a much cheaper and easier to replace... if that's the problem, Hmmmm
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
You could remove the control module from the ABS unit, and maybe fool the pintles with a magnet to activate the different ports to the manifold? Don't know if it would reveal anything though. And check your hose on the affected wheel, it may not look bad, but the core may be collapsing when pressure reduces (relative vacuum).
Current Volvos:
kallekula
Post by kallekula »
Milehighv70xc2 wrote: 10 Dec 2020, 14:52 Kallekula- I would agree since all for brake lines run separately from there. From the master the fronts run together and the rear run together to the abs block. I have been thinking something is clogged in the return port. I dont know very much about how that all works but from my research it seem pretty straight forward.
Exactly, you have two lines running from the master cylinder to the ABS. wouldn't you have two brakes locking up if it was the master that was faulty?
BMW 540i 2002
S70 Base 2000
