98-2000 ECC Cold Temperature Issue, 9171800 intermittent
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
Correct.
Also, I never use any Auto function of my ECC. Only manual fan speed, temperature, and vent position. I think it reduces wear and tear on the motors. Haven't had the AC on in a couple months.
Thinking it may just be capacitors or some part of the board that's getting weird with the freezing temps?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
It could be capacitors being out of spec on cold startups. I have a few ECC's which i can take apart and check to see if this is the case. I once had issues with a manual climate control unit after years of sludge built up on contacts and shorted motors together. This was fixed by cleaning all the motor contacts on the board. Theoretically, if it is just capacitors then we are in the territory of ordering upgrade parts and replacing them on the board to check. If someone posts a picture of the board then that could help.
2008 S60 2.5T Auto (Sold)
