Zip ties onto the inside of the upper grille. I used to find the zip-ties might pull through the cardboard at higher speeds. So run a couple of small washers through the zip-tie loop on the back of the cardboard to spread the load and pill the zip-tie tight at the outside of the grill.
This will work up to around +10C MAX!!!. Always watch the temp gauge when ambient temp gets above 0C (+32C) to be safe.
Sometimes the simplest solutions work the best. We call it the Saskatchewan solution. Lots of ingenious solutions come out of that province that are simple and effective.
There should be a small 4mm hole on the bottom edge of the intercooler near the lower hose or lowest part of the intercooler. I believe in the early days some cars did not have them so drill a small hole at the lowest point about 3/16" in diameter.
The problem may still exist even if you do this as there is a build up of oil in the intercooler from the turbo as it ages. It gets hard in the cold and acts like artery blockers and trap water/condensation in the cooling fins. I removed the intercooler and had a radiator repair company clean the intercooler before drilling and bolting the mounting brackets back on (the always fall off with time).
Good luck! Neil.
1998 V70 XC turbo After Cold snap, no power. [blocked frozen intercooler] Topic is solved
- Has thanked: 2199 times
- 54 Replies
- 10114 Views
Last post by cfelberg
- 16 Replies
- 3257 Views
Last post by hammertime
- 944 Views
Last post by overtcm
- 1785 Views
- 7098 Views
Last post by Suchy101
