850 ECC troubleshooting Topic is solved
JLv70t5
Year and Model: 1998 v70t5
Has thanked: 11 times
Re: 850 ECC troubleshooting
Post by JLv70t5 »
Thanks for the diagram i was lookimg for where a drain would be. I will check that hose as well. Seems like an odd place for a drain hose, it not being the lowest part. All the water was right under where the fan assembly sits
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
JLv70t5 wrote: 17 Apr 2021, 21:28 Thanks for the diagram i was lookimg for where a drain would be. I will check that hose as well. Seems like an odd place for a drain hose, it not being the lowest part. All the water was right under where the fan assembly sits
There might be a second drain molded into the casing. Run you hand back and check.
The other one is for condensation coming off the heat exchanger. The idea is to drain it away before it hits the fan.
