Outter TIe rod replaced now out of alignment
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
ignatz
Year and Model: 2006 S60 t5m
Has thanked: 17 times
Been thanked: 33 times
Re: Outter TIe rod replaced now out of alignment
Post by ignatz »
Hi cn90, Just checking the positive / negative.....in / out lingo. Wiki says, Negative toe, or toe out is the front of the wheel pointing away from the centerline of the vehicle. Just checking because your calling this Toe in with the negative wording.
Thanks Rob
In automotive engineering, toe, also known as tracking,[1] is the symmetric angle that each wheel makes with the longitudinal axis of the vehicle, as a function of static geometry, and kinematic and compliant effects. This can be contrasted with steer, which is the antisymmetric angle, i.e. both wheels point to the left or right, in parallel (roughly). Negative toe, or toe out, is the front of the wheel pointing away from the centreline of the vehicle. Positive toe, or toe in, is the front of the wheel pointing towards the centreline of the vehicle.[2] Historically, and still commonly in the United States, toe was specified as the linear difference (either inches or millimeters) of the distance between the two front-facing and rear-facing tire centerlines at the outer diameter and axle-height; since the toe angle in that case depends on the tire diameter, the linear dimension toe specification for a particular vehicle is for specified tires.[3]
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
Year and Model: 2004 V70 2.5T
Been thanked: 472 times
Post by cn90 »
Sorry,
My fault.
Toe Angle when the tires point inward, it is called "Toe-In" and expressed as positive values.
