Random question: for those that used the Fel-Pro HS 26204 gasket set, did it in include 20 plus 1 extra valve stem seals? I didn't bother to count them. During installation, I messed up one seal and threw it in the trash...but it seems I still ended up having enough seals to do all the valves...I hope I did not forget to install a seal in one of the valves. Don't really want to remove all the valves again just to check. Just a random question but I will try to peek in the ports if I can see the seals.
EDIT:
Answered my own question. Thank god for those ports on the cylinder head. I looked and found one valve where I forgot to install a valve stem seal . There I was thinking, "how nice of Fel-Pro to provide an extra seal in case one makes a mistake". Could've been a disaster.
What brand head gasket 3531017 Topic is solved
- Has thanked: 311 times
- Been thanked: 817 times
For posterity since it doesn't seem t appear elsewhere in this thread: I'd only buy the valve stem seals from Volvo. You can get a full set for about 80 bucks.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
^ That is exactly what I ended up doing. I just bought the Fel-Pro head gasket and not the whole kit.
1999 V70 GLT
1999 V70 GLT
Options
Volvo
Rein
Corteco
Elwis
You get the best shipping information when you order the Elwis brand, obviously.
Volvo
Rein
Corteco
Elwis
- 491 Views
Last post by erikv11
- 1079 Views
- 18 Replies
- 5884 Views
- 3402 Views
Last post by rspi
- 1748 Views
Last post by goddess357
