Pipe corrosion, odd bolt, extra bolts ? Topic is solved
- Clemens
- Has thanked: 473 times
- Been thanked: 219 times
Re: Pipe corrosion, odd bolt, extra bolts ?
The ones you have in there are the newer style replacement bolts. At least on my 94 that weird bolt you have are used instead of these regular bolts and they almost touch the timing velt. My theory is that they were supposed to keep the belt from jumping a tooth. Maybe the later p80s used regular bolts and therefore that weird long bolt was discontinued.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
- Has thanked: 1502 times
- Been thanked: 3817 times
I scanned the 94 and 96 engine fiches for that bolt with no success
Could that bolt possibly be one of the three special bolt you use to attach the flex plate , then remove to attach the ten “ regular bolts
9995756
9995756
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
No - I would have remembered that.
I installed the bolt in the lower of the two holes in that guard, but it ended up about 2mm away from the timing belt. Just seemed weird so I removed it and installed a standard bolt. But if a pic could be posted of it in place, I might go ahead and use it. I just don't quite get the purpose. Seems that if the belt wanted to jump a tooth, it would hit that bolt and score / cut the belt. But like I said, I just don't get it.
1999 V70 GLT
1999 V70 GLT
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 129 times
I just did my timing belt tonight, and both of the bolts in the lower cover were those weirdo bolts with the long shank. 10mm head, I think. As soon as I removed them, I was reminded of this thread. They even had the bit of red looking compound on the threads.
Unfortunately, I chewed the head up of one of them a little. I didn't have the wrench on it straight, and it kept slipping off. They were harder to get to than I had thought. It's still in decent enough shape to do the job, Though.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Can anyone find a part number fir these funny long bolts to document them here please
- Sveedy
Well then I guess I'll pop it in one of the lower holes and call it good.
1999 V70 GLT
1999 V70 GLT
454cid
You want me to find a part number, to a bolt??? I can't even find a cup holder, or a trunk light without help
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
974674 ? superseded by 985031
Couldn't find a pic
Couldn't find a pic
- 2101 Views
Last post by mickjenkins
- 347 Views
Last post by MoVolvos
