Herman and Operation 30MPG
- Has thanked: 1613 times
- Been thanked: 4078 times
My 1999 manual says I should put in 91 octane (that is the US 91) with the minimum requirement of 87.
My 99 turbo has a compression ratio of 8.5:1
My 05 NA has a ratio of 10.5:1
Im a bit less picky about the 99 as I drive it off boost for 95% of the time. The 05 gets 91 or 93 depending on how rich I feel.
- June
- Has thanked: 523 times
- Been thanked: 261 times
Correct me if I am wrong, but the 8.5:1 increases durring boost and is the reason turbo engines don't have 10.5:1 as a starting point? Juneabscate wrote: 13 Mar 2018, 12:27 My 1999 manual says I should put in 91 octane (that is the US 91) with the minimum requirement of 87.
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Effectively compared to atmosphere pressure, yes. So a turbo will lose more performance relative to its max output when the boost kicks in if it detects pre ignition due to poor fuel.June wrote: 13 Mar 2018, 13:05Correct me if I am wrong, but the 8.5:1 increases durring boost and is the reason turbo engines don't have 10.5:1 as a starting point? Juneabscate wrote: 13 Mar 2018, 12:27 My 1999 manual says I should put in 91 octane (that is the US 91) with the minimum requirement of 87.
The compression ratio, formally defined, of the engine is constant but there will be higher pressure in the cylinder in a turbo, so it is effectively a higher compression ratio. Im not sure how much extra charge a turbo pushes into a cylinder - sounds googleable though.
- Rattnalle
How much depends on the car and how high the boost pressure is. But yes it seems googlable, I just did and found a bunch of articles discussing static vs effective compression ratio though I didn't read them.abscate wrote: 13 Mar 2018, 14:20 The compression ratio, formally defined, of the engine is constant but there will be higher pressure in the cylinder in a turbo, so it is effectively a higher compression ratio. Im not sure how much extra charge a turbo pushes into a cylinder - sounds googleable though.
I was hoping to get someone else to jump into he sinkhole of people talking about this stuff without having a clue of knowledgeRattnalle wrote: 13 Mar 2018, 14:26How much depends on the car and how high the boost pressure is. But yes it seems googlable, I just did and found a bunch of articles discussing static vs effective compression ratio though I didn't read them.abscate wrote: 13 Mar 2018, 14:20 The compression ratio, formally defined, of the engine is constant but there will be higher pressure in the cylinder in a turbo, so it is effectively a higher compression ratio. Im not sure how much extra charge a turbo pushes into a cylinder - sounds googleable though.
- Rattnalle
It's what I do professionallyabscate wrote: 13 Mar 2018, 14:28I was hoping to get someone else to jump into he sinkhole of people talking about this stuff without having a clue of knowledgeRattnalle wrote: 13 Mar 2018, 14:26How much depends on the car and how high the boost pressure is. But yes it seems googlable, I just did and found a bunch of articles discussing static vs effective compression ratio though I didn't read them.abscate wrote: 13 Mar 2018, 14:20 The compression ratio, formally defined, of the engine is constant but there will be higher pressure in the cylinder in a turbo, so it is effectively a higher compression ratio. Im not sure how much extra charge a turbo pushes into a cylinder - sounds googleable though.
- June
It's a lot more fun than discussing vacuum cleaner vs broom. Oh wait I ride the latter!abscate wrote: 13 Mar 2018, 14:28I was hoping to get someone else to jump into he sinkhole of people talking about this stuff without having a clue of knowledgeRattnalle wrote: 13 Mar 2018, 14:26How much depends on the car and how high the boost pressure is. But yes it seems googlable, I just did and found a bunch of articles discussing static vs effective compression ratio though I didn't read them.abscate wrote: 13 Mar 2018, 14:20 The compression ratio, formally defined, of the engine is constant but there will be higher pressure in the cylinder in a turbo, so it is effectively a higher compression ratio. Im not sure how much extra charge a turbo pushes into a cylinder - sounds googleable though.
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- Rattnalle
A vacuum cleaner is a turbo charged broomJune wrote: 13 Mar 2018, 15:01It's a lot more fun than discussing vacuum cleaner vs broom. Oh wait I ride the latter!abscate wrote: 13 Mar 2018, 14:28I was hoping to get someone else to jump into he sinkhole of people talking about this stuff without having a clue of knowledgeRattnalle wrote: 13 Mar 2018, 14:26
June
- 1243 Views
- 2245 Views
- 1453 Views
- 771 Views
Last post by shiloh51933
- 12 Replies
- 3360 Views
