850 Hydraulic clutch Issue
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
abscate wrote: 04 Jan 2023, 19:59 Well, here is a tasty tidbit.
Three failed attempts to bleed the clutch, getting some action but then losing it.
Finally I set it up to gravity bleed to try and get the air out. I noticed that the fluid level dropped very little, like 1.5-2 cm
A flash of inspiration. The clutch pickup tune extends well up into the reservoir so the brake master cylinder reservoir has to be full to overflowing to bleed the clutch. I was basically pushing fluid through until the tube sucked air, then destroying my bleed process.
Reverse bleeding should've solved that issue. (Unless this just was an after-the-fact epiphany).
Has thanked: 1611 times
Been thanked: 4075 times
Chuck W wrote: 05 Jan 2023, 05:49
Indeed, Chuck, that’s the right way to do this. I was looking for a syringe or pump to do that while I gravity bled it, then noticed the reservoir stopped dropping consistently after 2 cm drop level. Epiphany indeed surfaced.
Has thanked: 2210 times
Been thanked: 1852 times
I am wary of reverse bleeding. A dealer did that on a 240 I had and first time I used the brakes on leaving the dealership there were none!! They had damaged the valve which was not designed to have reverse pressure on it. There is a reason you get all those suction bleeders and also the pressure bleeders. Not having fluid to get drawn into the system does make it a challenge! Good catch on that absacte!
