Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
I have had good success with contact cement for these type mounts on this fiber board. Clean the old glue by scraping. Apply contact cement to both surfaces and wait until tacky. If it is no longer tacky because you had too many surfaces to apply contact cement, then reactivate the cement with acetone.
A primer coat of thin contact cement may be helpful if the fiber board soaks up the cement.
Clean up excess with acetone.
Has thanked: 2210 times
Been thanked: 1852 times
Having done this several times, I use JB Weld Plastic epoxy or Marine GOOP for the plastic pieces to the card and use clamps and pieces of thick cardboard on the outer faces of the panels to prevent the clamps marking and leaving an indent.
For the panel to panel sections, I use PL XL? construction adhesive and again using either clamps or just a weight on the inner part laying the whole panel face down.
So far none have come apart and the longest being 10 years.
Don't go too hard on the previous owner other than for not keeping the parts. One of the most important is a piece that looks like a coffin or T-piece in white that sits at the top rear edge of the panel and sits in a slot in the metal ridge on the top of the door panel. It takes the weight of the door panel and heavy elbows to prevent straining the other mounts.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Finally took 5 minutes to quiet down the rattle-y tailgate on her 855 over the weekend. It always bugged me when I drove it, and I noticed that the striker had very little, to no bushing on it. The Tailgate would lift ever-so-slightly, and thus the rattle.
5 minutes and a short piece of black nylon tubing with a slit cut in it later (Like the fuel and vacuum tubing) and there is no more rattle.
It's amazing how often the little, simple things just get overlooked in the sea of everything else that needs to be done.
Has thanked: 1611 times
Been thanked: 4073 times
Silconed sprayed the sunroof tracks on the Silver Kat (S70 AWD) which nicely restored sunroof function.
Will order a cheap small bottle for the car in case it sticks on the road.
I used the same spray to lube the birdfeeder poles and now can watch squirrels unsuccessfully try to climb it, and slide back down frustrated. Its a hoot!
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
There’s a squirrel Olympics series on YouTube, if I recall correctly. I’d definitely watch!
This week, I changed the oil in Blue Steel and used the LiquiMoly anti-friction additive (which I could almost swear quieted the engine noticeably). Then I broke one side of the air guide (splash guard) once again. The fun never ends!
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
Used Elizabeth to chase parts for Juliette brake job.
Got stuck as the pad thickness is too big for caliper. Wrong part?
brunocerous
When I struck a curb earlier this week and broke my air guide / splash guard, I apparently also broke my radiator mounts. Today, driving home from the train station, I heard a dragging that turned out to be the radiator, which is now bent but still somewhat intact.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Ooof! That happened to my cousin's V70 before he bought it. The intercooler had been totally worn through on the bottom from it hanging after the previous owner had hit something. By some miracle, the radiator held coolant even after taking on similar damage.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
abscate wrote: 08 Mar 2024, 16:42 Used Elizabeth to chase parts for Juliette brake job.
Those hoses look a little rough, but that acorn looks to be in great shape!
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
454cid
Post by 454cid »
brunocerous wrote: 08 Mar 2024, 21:22 When I struck a curb earlier this week and broke my air guide / splash guard, I apparently also broke my radiator mounts. Today, driving home from the train station, I heard a dragging that turned out to be the radiator, which is now bent but still somewhat intact.
Weird, I have the driver's side radiator mount broken on my S70 and its a few inches low, but otherwise seems to hold. It was getting 100 miles a day until I hit the deer a week ago (radiator was prior to the deer hit).
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
