In many States, you can pass inspection with your car on fire. Flames have to be smaller than 6 cm though.xanthefin wrote: 08 May 2024, 09:31Ooh okay i see. Thanks for information i keep in mind this detail.
Ha! I need tell you then too that they here inspect even colour of your turn signal bulbs. If their yellow layer has been burned off (so its more white flash) you get fail notice on paper about it if they spot it.bmdubya1198 wrote: 08 May 2024, 08:09 Inspecting based on light pattern... meanwhile here, you'll pass inspection as long as there is light being emitted from the front end. Doesn't matter if it's a headight or a flashlight.![]()
- Has thanked: 1613 times
- Been thanked: 4078 times
- Has thanked: 987 times
- Been thanked: 1078 times
I some states (Oklahoma) there is not inspection at all. Run whatever you've got.
- Has thanked: 317 times
- Been thanked: 531 times
We're not animals, a larger flame would possibly obstruct the view. Also, we use inches here, none of that metric stuff!abscate wrote: 09 May 2024, 04:51
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
It's quite amusing the death traps that are allowed to drive on the road here in the US.
- ZionXIX
Finally changed out the xc90 struts that have been sitting in my garage for 3 months. This was my first time changing spring as well. I used 2 sets of compressors so 4 total. Despite the added security I was still quite nervous. I had to max out the compressors to remove the spring. Also I didn't have a tool for the cross nut and no amount amount of hammering or misuse of a box end wrench would move the cross nut. So I sacrificed one of my harbor freight sockets. The driver side spring seat had blown through which explains the clunking noise I was hearing. Now on to the blend doors
- Has thanked: 2215 times
- Been thanked: 1853 times
There are 'star nut' tools out there. Amazon in Canada lists OEMTOOLS version for about $22 CDN ($17 US). I would link it but links from Canada don't work when viewed in US from Amazon.
- ZionXIX
I've seen several but none were available to me locally same day so I improvised. I have no regrets.scot850 wrote: 09 May 2024, 10:16 There are 'star nut' tools out there. Amazon in Canada lists OEMTOOLS version for about $22 CDN ($17 US). I would link it but links from Canada don't work when viewed in US from Amazon.
I hear you, and love the improvising! I am fortunate to have the Volvo tool for front and rear as I got fed up fighting this issue.
Custom tools often work better than the actual thing!
RedBrickCollector
- Year and Model: 1997 850 T-5 Wagon
- Has thanked: 40 times
- Been thanked: 29 times
Had my engine and trans mounts done at a local Volvo specialist. Feels great but unfortunately can't fully enjoy it as now the car doesn't start with the key. Checked the usual suspects but the shop and I are both stumped. I'll be relaxing a little before making a full post.
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
