Glad the grandson is carrying on this craft! We need skilled people who rebuild things, too many cheap operations going on now. For example, every cheap reman part at the auto parts stores.
- Has thanked: 304 times
- Been thanked: 517 times
- Has thanked: 1850 times
- Been thanked: 1712 times
Agreed. All we can do is to root them out and use them so they stay in business and hopefully can take on an apprentice.
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 131 times
I need to contact the local-ish shop that I know of. Its in a smaller town, that I drive through on my commute to work. I have the original starter from my truck (the 454) that I'd like to get rebuilt. I also have an alternator to rebuild from my 69 Buick, but I think I might do that myself.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
I had thought about rebuilding the alternator myself. But it would have ended badly as I had assumed it was a Bosch alternator and not a Bosh reman of a Denso unit. Also, it wasn't just a case of a tired unit needing rebuilt. The car has about 150,000 miles on it with a rebuilt alternator. So I am assuming the unit can't have done a big mileage. So something has possibly gone wrong with the unit and that is way out of my pay grade. I have no qualms of taking an alternator apart, cleaning, replacing bearings and the likes, but these are a bit more complicated. They have the section at the back is soldered in on 3 different double pins which will need serious de-soldering kit. I will pay for the knowledge learning in this case and then I would tackle one again in the future. A P80/P2 alternator does not worry me, but again, it is easier if it is not faulty.
Back home today I finally took the covers of the 'princess' and pushed her into the new garage for room to swap the RH storage rims/tires over for the summers. A quick check of all the fluids (done before storage last winter), removed the fuel pump relay and got my son to crank the car a few times. Strangely, even after a few spins the oil light had not gone out. Put the fuse back in and the car started immediately and ran smoothly. The 'boss' who is the main driver now (and the reason it has not been sold) will have to take it for a few runs and when my mechanic buddy returns from vacation, we can swap the timing belt over and I might also do the coolant. The car has only done maybe 10,000 miles since 2012, and had a new radiator maybe 6 years ago (and maybe 3,000 miles ago) but it could do with a coolant swap. The brakes were bled about 3 years ago, but maybe worth doing the fluid flush in the fall before winter.
Oil has done about 300 miles on synthetic so it can also stay until the winter layup and replaced then.
With the timing belt, I plan to just swap the belt as the water pump, tensioner and idler have done maybe 10k miles in 10 years. I have a new Volvo belt ready to go on.
- Has thanked: 1506 times
- Been thanked: 3818 times
In ozone free Calgary I would inspect the belt and timing gear and run them with 10 k miles. They fail on miles , not time, if you keep them free from oil. My T5 went 14 years 150k on its OE parts,100k 9 years on its second, and almost one month on the third INA roller…
RedBrickCollector
- Year and Model: 1997 850 T-5 Wagon
- Has thanked: 40 times
- Been thanked: 28 times
There's a place local to me well known among car communities. I wonder if it's because ordering parts is more difficult, but it's still common enough here. I worry that the owners are getting old but at least the guys doing the work have managed to train up a next generation. Been about 4 different alternators I've brought them over maybe 10 years but they somehow still remember me. They're busy enough that I've never been there alone and there's a good number of alternators, starters, etc in the claiming section.bmdubya1198 wrote: ↑07 Jun 2024, 07:40 Glad the grandson is carrying on this craft! We need skilled people who rebuild things, too many cheap operations going on now. For example, every cheap reman part at the auto parts stores.
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
RedBrickCollector
While getting to know the fuel system for our cars more, I started looking into what's so special about our fuel pump relay that makes it a special part and not just a standard relay. Is it just a timer circuit for priming on startup? or is there more to it?
Mostly I'm wondering because I see there are upgrade/replacement kits out there.
'97 950 T-5 Wagon
RedBrickCollector
I'd like to thank the other guys for bumping the 10 page fuel pump relay discussion haha
'97 950 T-5 Wagon
jsrnsis
- Year and Model: P80 enjoyer
- Has thanked: 25 times
- Been thanked: 68 times
What a nice looking car.
Here's my unfriendly reminder to everyone to wash their car.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
That is a tidy organized garage Neil.
We have a good auto electric shop here. Old school. But I took an alternator and an old generator in to have rebuilt, and they couldn’t do it. They do a lot of Bosch, but they looked up the numbers and they couldn’t get the kits. Their work is primarily semi’s and big work trucks. So no luck.
