- ZionXIX
- Has thanked: 64 times
- Been thanked: 194 times
Re: What did you do to your Volvo today? (now Sticky!!)
Today I unbolted the 3rd row seat belt and discovered that the assembly tucks neatly away into the side panel.
- ZionXIX
Finally got the fuel tank repaired and installed only to find these bastards disintegrated.
- Has thanked: 1500 times
- Been thanked: 3812 times
Flight with right headlight, outside M6 bolt, found captive nut in headlight was no longer captive. Apparently Stockholm syndrome did not apply. Secured with zip tie. Installed new right turn signal to get rid of painters tape, finally.
New spark plugs, mine look a little rich on shoulders , grey/ white on nose.
New fog light
Oil on top of head. Removed cover and cleaned off. Will monitor
New fog light
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 126 times
Friday - drained coolant, removed lower radiator hose's upper connection near right side of engine. Cleaned nipple and reseated hose on it. Installed constant torque hose clamp. Torqued to spec roughly via man power.
So far no leaks there. Now need to look into the potential of the heater core or the connections to it (o-rings) potentially leaking.
- Has thanked: 304 times
- Been thanked: 517 times
Finally is right!
At least you didn't Gorilla tape the crap out of it like some people do. They'd rather ruin their paint instead of replacing their turn signal.
- Ocelot
- Year and Model: 1998, S70
- Has thanked: 61 times
- Been thanked: 17 times
So today I did changed a few things on my S70. First of all, I changed the oil and oilfilter. Then, I changed the brakefluid. I borrowed a tester from a friend of mine and it said it had 3% water in the system. Then I changed the airfilter and the cabinfilter. But then...
I noticed the box in the left of the engine bay (see pictures below).
https://photos.app.goo.gl/e65rLH8VdecbvqRTA
https://photos.app.goo.gl/LRdHk9HXHg2QgXPf7
Can anybody tell me what it's for?
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
Recent car
- RickHaleParker
- Been thanked: 958 times
It contains the ECM (Engine Control Module) and the TCM (Transmission Control Module).
- Ocelot
Well, I was a little dumbfounded when my S70 just a hour ago refused to run. It would crank, start and run for a second and then shut of. I read something about faulty immobilisers and stuff, so I opened and closed the doors five times in a row with the keyfob and then the problem was solved. Question: how do I fix this on the long run?
Recent car
Recent car
You just did.
You let the car find the key and be happy with it. Run it, and I bet you wont have a problem.
