Chieber
Year and Model: 1998 v70
Has thanked: 45 times
Been thanked: 30 times
Post by Chieber »
scot850 wrote: 12 Jun 2025, 10:22 I was about to ask if yo had replaced the orifice valve/filter, especially as you said you found debris in the system. Glad to see you had a picture of the valve and it had done it's job!
Major work you are going through. Very satisfying though!
The work is quite easy I found. The good thing about older cars is that you can reach everything quite easily.
And it’s for sure satisfying to put everything back together and finding out that it works again.
Sveedy wrote: 12 Jun 2025, 14:03 Where exactly in the system Is that orifice filter located ? Is it in the tube ?
It’s in under this large tube where the two a/c pipes run through the firewall coupling.
1/2 a shitbox V70 1998 2.5 NA
Has thanked: 1505 times
Been thanked: 3818 times
Rolled the P2 up to Albany and got rid of old blocks and junk for scrap
Moving engine blocks by yourself is hard but I got it done !
Broke my personal best for my morning Mile run
And got a free concert coming home on the ferry!
What’s that car, foggy?
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
abscate wrote: 13 Jun 2025, 03:36 Rolled the P2 up to Albany and got rid of old blocks and junk for scrap
Looks like a pre-or-just-post war Plymouth. My brother had one in college, the juice in the radiator was exactly the same as the juice in the pan, sort of a thin chocolate milkshake stuff. Drove it all around Houston - a Very Large City - ran fine the whole time I was there. Gone when I got back from the Pacific, replaced by a later Plymouth four door, same indestructible flathead six.
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
FAR Y88 ?
BlackBart wrote: 13 Jun 2025, 08:27 FAR Y88 ?
No idea. Y88 was a Trans-am thing wasnt it?
BlackBart
Post by BlackBart »
You'll be running 4 minute miles and going to the Olympics soon!
Chieber
Post by Chieber »
Was at a picknpull today and came across this fuel relay solution.
Anyone ever saw this done before?
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 130 times
Post by 454cid »
How are you supposed to get good parts off of stacked cars?
I like the brick and cement instead of dirt or gravel, but the stacked Volvos hurt to see.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Really nice clean junkyard, no parts lying around.
That fuel pump relay bypass is fine for testing but you really shouldn’t run like that all the time. If the engine quits the relay turns off the pump whereas it will keep running with the wire, of course. A rollover crash would leave the pump dry and running with some fiery results
Chieber
Post by Chieber »
454cid wrote: 14 Jun 2025, 19:50 How are you supposed to get good parts off of stacked cars?
Unfortunately, because of the age of the Volvos they’re seldomly seen at the picknpulls.
I think they stack all the cars due to lack of space.
There’s a ladder ppl can borrow to get on top, but officially you have to ask for an employee to move the car to level ground.
abscate wrote: 15 Jun 2025, 04:18 Really nice clean junkyard, no parts lying around.
Ah, that’s good to know!
