Coronavirus Thread
Forum rules
ToriWhite
- Year and Model: 1996 850
- Has thanked: 20 times
- Been thanked: 6 times
Luckily I’m in a relatively trivial, low pop county in CA - but our neighbor SF basically said “Don’t go outside unless your life depends on it” - read somewhere there’s 20+ confirmed homeless in SF.. ! I hope as interesting as things get down there, it doesn’t come up here- We’ve got our own local homeless population, too.. Everywhere in CA does these days
- Has thanked: 1611 times
- Been thanked: 4072 times
I can confirm there are 20 homeless people in SF.
See June ? Its a guy thing. Never fill your tank fully in case you see gas cheaper on the way, and aways wait for the little yellow lightI've never had my gas gauge so high, I paid $2.28/gallon for 93 the other night.
- Has thanked: 987 times
- Been thanked: 1076 times
What? there is a yellow light? I've never seen it.
volvolgnut
volvolgnut
DrJammer
- Year and Model: 2000 V70XC - 195k
- Has thanked: 1 time
Running your tank low is 1 way to see the little yellow light. Another is to have the local mechanic replace a fuel pump and not do a new fuel level sender unit. I'd be willing to do that in a month long quarantine. It's a 2000 AWD, assuming I'd still need to drop the rear suspension to fix........or is it time to cut the flap?
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
2008 S60 - leased
Neil will guide you on that. Summary - if you drop a early AWD platform, you have to deal with a bunch of corroded No-longer-available suspension parts.
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Medically speaking, here's the best overview I've seen
Why Covid-19 is so dangerous for older adults
- Has thanked: 316 times
- Been thanked: 531 times
I try to avoid letting that light come on, but sometimes it happens. But especially now, it's best to wait for gas to get even cheaper!abscate wrote: 17 Mar 2020, 10:34See June ? Its a guy thing. Never fill your tank fully in case you see gas cheaper on the way, and aways wait for the little yellow lightI've never had my gas gauge so high, I paid $2.28/gallon for 93 the other night.
Yup, it can be a project, that's for sure. I've been putting it off, I need to drop the rear subframe at some point and replace my fuel pump. I was thinking about cutting the flap, but I'd rather not have a hole in my floor.abscate wrote: 17 Mar 2020, 14:50 Neil will guide you on that. Summary - if you drop a early AWD platform, you have to deal with a bunch of corroded No-longer-available suspension parts.
There's a way to get one side of the subframe/tank down without totally removing the subframe. The sender is part of the fuel pump assembly on the AWDs, isn't it? There's just a surge pump on the driver side, so I don't think you should need to get to that.
- RickHaleParker
- Been thanked: 980 times
Took out the trash today and seen somebody had thrown away a perfectly good roll of Toilet paper. That is when I knew I was not alone in the world.
Active
Past
Past
