2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
absacate is a wannabe with only a stable. Real Volvo owners have a full fleet. Of course, his stable mostly runs.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Starbuck wrote: 25 Aug 2020, 06:15 Were there two blues?
For the 2004 V70, V70R & XC70 only one blue: Nautic Blue Metallic (Code 417). Check it against the product ID plate.
Mdava666
Year and Model: 2005 XC70
Post by Mdava666 »
In the last 2 days I drove my ‘05 XC70 from Newcastle to South Wales and back(~750mi round trip).
I’ll be very surprised if I don’t end up with a ticket for my return leg, I clocked myself at 110 on the way home.
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 64 times
Been thanked: 69 times
Post by Georgeandkira »
Do what so many do nowadays.....set up a "Go Fund Me" page for the fine and insurance premium increase.
Then, if no ticket arrives keep the funds.
Oil + filter change, trannie D&F, P/S reservoir D&F.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Mdava666 wrote: 26 Aug 2020, 07:07
110kilometers per hour is only 68+mph. 70mph is the speed limit here with some sections @65mph.
Mdava666
Post by Mdava666 »
[/quote]
[/quote]
UK is mph and that’s what I was clocking in, not kph
Yesterday low coolant warning came on 1/2 mile from home. I found the coolant level at bottom of resovoir and lower radiator hose clamp was loose. I must not have gotten it fully in place and tight back in June when I did water pump and other work. Very glad it did not blow off on the highway!
Today it helped move 7 bookcases (33 x 84 x 8 inches) in 3 trips across town. Tailgate and all windows were open.
daughtersmechanic
Year and Model: 2001 V70 XC
Post by daughtersmechanic »
Spent the weekend replacing the right rear hub on The Beast. Probably spent as much money accumulating the tools as it would have cost to have the local Volvo guy do it, but don't tell my wife! Much quieter now, but I think I hear the beginnings of the left side going, so maybe I'll get to amortize all that equipment. Changed the oil last month and replaced the missing splash guard. Hoping the pulsating brakes are just accumulated rust from it sitting in the driveway since February. Daughter is living with us while we ride out the pandemic (lots of elevated risk factors in this family)
2001 XC70, The Beast, 222K
Mike Langlois
Year and Model: 2002 V70 & V70 XC
Has thanked: 28 times
Been thanked: 6 times
Post by Mike Langlois »
Upgrading 2002 V70 X/C: Pulled off exhaust, turbo and broke off a heat shield bolt in the exhaust manifold. Found some minor leaks in the exhaust manifold, so it was not a total loss. Then I found a small leak in the cylinder head gasket; this is a minor inconvenience to repair at this point, as everything is disassembled. I guess I will port, polish and do a valve job too. Also got the angle gear out for a re-seal and spent quite a bit of time scraping off the first layer of accumulated dirt prior to pressure washing. Smoothed and polished the inside of the exhaust manifold just because...
Manic Mike
Has thanked: 1502 times
Been thanked: 3817 times
Mike Langlois wrote: 02 Sep 2020, 23:47 Upgrading 2002 V70 X/C: Pulled off exhaust, turbo and broke off a heat shield bolt in the exhaust manifold. Found some minor leaks in the exhaust manifold, so it was not a total loss. Then I found a small leak in the cylinder head gasket; this is a minor inconvenience to repair at this point, as everything is disassembled. I guess I will port, polish and do a valve job too. Also got the angle gear out for a re-seal and spent quite a bit of time scraping off the first layer of accumulated dirt prior to pressure washing. Smoothed and polished the inside of the exhaust manifold just because...
Manic Mike
Leave out that last exhaust stud until after you put in the water pipe gasket
:D
