Yeah, that is a successful flash. Hitting the "Flash" button in the pop-up will just repeat the process. Not sure if the way that it works is a bug or a feature. : )gwcook wrote: ↑15 Mar 2025, 19:24
Thanks a ton for the reply, I think I got it to work!
No issues with the installation/setup for the M4.4 flasher plugin, I had everything properly set up there.
Included another ground ECU pin in the harness and bumped the voltage up to 16.2v, opened the flasher plugin with the bin already loaded into TunerPro, and it automatically provided the following outputs in the plugin window (approximately, can't remember for sure what it said verbatim):
>Preparing flasher
>Preparing to erase flash
>Erasing flash
>Flash erased
>Preparing to flash
>Flashing
*here the little green progress bar began to fill, i think it also said something about installing flash*
>Flashing complete
I then closed out of the window after nothing happened for a while, and shut off the power supply.
A couple questions just as a sanity check:
1. Does this seem like a successful flash? I'm not sure of any way to confirm that it actually did what it claimed to have done (in other words, do the outputs of the plugin in my case align with what a successful flash outputs in your experience?)
2. I never had to click on the "flash" button in the bottom right corner of the plugin window to select the .bin, does this mean that it automatically selected the bin I had loaded into tunerpro and flashed it onto the ECU? The plugin just started doing things as soon as I opened it.
3. I flashed the 608rev5b.bin file onto the ECU - are there any mods I need to make to the .bin maps prior to installing the ECU into my car and starting it? I have a stock US spec '98 V70R (stage 0, quite a few new OEM parts like vac lines, PCV, plugs, distributor, TCV, etc.), the only real changes I've made that would affect a tune would be that I've manual swapped it, and done an SAS delete (I will be getting another diode to install into this sacrificial ECU to accommodate that prior to installing it). I'm not sure if the euro spec HPT maps are compatible with the US spec HPT hardware, and definitely don't want to be replacing an engine if the .bin isn't compatible and makes explosions in the wrong places.
Lastly (for now), a note on the flashing that may help some others in the future: the only way I was able to get it to work was by restarting my computer (using the power button and waiting at least 10 secs before turning back on, not just clicking the restart button), opening TunerPro RT and flashing once everything was connected. Was unable to do another flash without restarting everything again.
Not sure why you have to restart your PC to get it to flash. I've used 2 or 3 different laptops and haven't encountered that issue.
On any changes needed.
- No need to add the diode to the ECU. You can disable it in the Diagnostics Disable section. "secondary air system". Disable both banks. I think all of the others that need to be disabled are already done so by default.
- The injectors the bin is calibrated for are the "blues" or "whites" . If you have something different in there, you'll need to adjust as per the info on the Wiki page. It's all there.
- The US V70R ECU (-455) is a bit more aggressive than the -608 T5 bin. I don't have any .bins for the V70R to compare, but I do have the -612 and -606 bins, which were B5235T4 and T6 tunes for the V70R's and the V70 AWD, etc. If you want to send me a message with an email, I can send those over. You can use those to compare/copy/paste into the -608 file to bring it up to where it is with the stock ECU. Drive it with the -608, and you'll notice a difference from current. Ignition and fuel maps, as well as turbo duty-cycle and target load setpoint will be the big ones to look at.
