ECM A17 is connected to pin 2 of MAF.
When I checked pins for incoming voltage at ECM (with ECM removed) I had no voltage.
At B11 there was 12V.
Now I do have 12V on pin 2 on the MAF and I do have continuity between all MAF wires and CEM.
Doesn't this say that if I check the ECM pins from the back I would read 12V on pin A17 ?
Or are we talking about another pin / another page?
Throttle body cleaning issues EPIC Volvo saga...RESOLVED!!
Engine management system ME7 5-Cylinders page 40.pdf- Eng Manag Sys
- (40.31 KiB) Downloaded 162 times
S60 2002 180K miles looks and runs like new (except when sulking)
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
That's the page, so it looks like you do have 12v getting into the ECM. How about the grounds at the bottom of the page - (going into ECM)?
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
Sorry, I'm confused. You mean lines C and D ? or the three A:54 A:63 A:53 ?
It s curious they was I understand electrical drawings, when lines are connected and bundled between separate and similar elements it is indication that this is ground.
In this drawing (Engine management system) pin 1 of 8/6, 8/7, 8/9, 8/9, 8/10 and pin 2 of MAF are connected but pin 2 of these are independent. This looks like they are the negative, Ground. Yet I get 12V positive on pin 2 of MAF.
BTW are these 8/6,8/7... the injectors?
draser
The 8/n devices - which are the injectors - have a common "junction point" 53/315. The batt voltage from fuse 11/B6 gets there, and to pin 2 of MAF.
The grounds for ECM are at the bottom of diagram, A53, 54, 63 and go to junction point 53/325 and from there to car chassis at 31/96 (which is on left fender I believe).
So you were correct. There's a legend in the first pages of wiring diagram booklet the explains all that, also a list of ground locations in the car. I could not find a list of junction points.
draser
Forgot about lines C and D, thay are positive batt voltage, one you don't have (dotted) the other (C) goes to pedal sensor pin 1.
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
If you scroll down to the last two pages of the wiring diagram you will find a list of component numbers and descriptions which makes it easier to find out what is what.
Look at page 119 for a diagram of junction 53/315
Look at page 129 for the location of the junction in the engine harness, note there are two different locations for this junction depending upon 5 cyl or 6 cyl - Mike
I called a dealer (no names please) to ask whether they could test the ECM "just the ECM, I said.
Well, they "have a machine to test [that], they want the car over there, and they will charge me whatever time it takes to discover whatever it is" And of course I have to tow the car.
There goes my hope of having an independent look into the CEM.
Must be bunch of retired civil servants working there.
What if I added 12V via a needle to the back of 12V pin going into ETA?
Would that blow my garage?
draser
Can't apply straight 12v to ETA. How about having Xemodex test it, they can bench test it for correct voltages at ETA area pins?
precopster
- Year and Model: Lots
- Been thanked: 128 times
The "machine" is Vida Dice. They just know the test points a little better.
Lucky from ARD can do the same thing without the car.
Be sure that whoever you send it to has the ability to clone a used ECM. I don't think dealers can do this; only initialise a nice shiny new one.
- 97 Replies
- 15503 Views
Last post by bmdubya1198
- 16 Replies
- 4225 Views
Last post by daninater
- 8814 Views
Last post by MadeInJapan
- 1432 Views
Last post by 800artfreed
- 37 Replies
- 37672 Views
Last post by chitownV
