Save a photo onto your computer, or post a photo here? Or both?
- Has thanked: 2858 times
- Been thanked: 1332 times
- Been thanked: 4069 times
Not bad shape, key is jacked and stuck in ignitionfoggydogg wrote: 15 Apr 2021, 20:22 '05 XC90 V8 at the auction house in DC
https://www.capitalautoauction.com/inve ... b38349a4e6
Very curious thing going on with the ignition key.
Still can't figure out how to capture a pic
Plan on $400 to fix that.
- RickHaleParker
- Been thanked: 979 times
My 2005 would get stuck in ignition when I first got it. I pulled the interlock cable toward the column lock and tied it down with a piece of solid aluminum wire. No more key stuck in ignition. The plastic jacket on the interlock cable shrinks as it ages. Basically the same problem as the drive cables in power seats.abscate wrote: 16 Apr 2021, 05:13 Not bad shape, key is jacked and stuck in ignition
The big problem I see is the key transponder is not attached to the key. Not a deal killer IF they have the transponder.
Active
Past
Past
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
For some reason their pics won't compute on my end; Steve may be doing some screenshot VooDoo that also escapes me. Posted a pic from the 444 C/L ad, though.
- foggydogg
- foggydogg
I figured if it could be had cheap, I would put it under the pin oak and play with it at my leisure. Hammered for $1100, plus about $300 in fees - not to mention shipping. At this point my new toys can't be so dear.abscate wrote: 16 Apr 2021, 05:13Not bad shape, key is jacked and stuck in ignitionfoggydogg wrote: 15 Apr 2021, 20:22 '05 XC90 V8 at the auction house in DC
Plan on $400 to fix that.![]()
- foggydogg
'96 850GLT near DC, big ask but way low miles and looks right clean.
https://washingtondc.craigslist.org/nva ... 64695.html
- 96 850GLT.jpg (56.95 KiB) Viewed 1263 times
- foggydogg
'67 122, a bit skeptical about the 'S' claim.
https://washingtondc.craigslist.org/nva ... 23088.html
Responsible Citizen has the popular corrrigated oil catch-mat under.
Pretty big number for an auto, and about the paint mismatch ...
- 67 122 2 door.jpg (58.68 KiB) Viewed 1261 times
- Has thanked: 311 times
- Been thanked: 817 times
38k is very low miles indeed, "possible the lowest mileage 850 in the USA" to quote the over-used phrase. If all that service was done by the dealer (or by a shop but with the right parts, which is essentially never happens) then it may be worth the big ask. If done with aftermarket then watch out, would just be buying a bundle of upcoming service.foggydogg wrote: 17 Apr 2021, 14:03 '96 850GLT near DC, big ask but way low miles and looks right clean.
- Has thanked: 2205 times
Here are a few interesting possibilities for someone out there:
Never seen a stick version of one of these:
https://www.kijiji.ca/v-cars-trucks/cal ... 1561910888
This C70 has an 'oopsie' that needs fixed:
https://www.kijiji.ca/v-cars-trucks/edm ... 1562069733
Then there is this low mileage late model C70:
https://www.kijiji.ca/v-cars-trucks/edm ... 1562039198
Abscate, do you need another one?:
https://www.kijiji.ca/v-cars-trucks/cal ... 1562042327
S70 AWD 00 year.
S70 AWD 00 year.
