PCV service turns into oil pan work.
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Has thanked: 1497 times
Been thanked: 3809 times
Re: PCV service turns into oil pan work.
You can beg borrow or steal a used oil filler cap , and drill a hole into it, to vent the crankcase to a tube running under the car. This will save your seals from popping out.
altalake
Year and Model: 2004 XC70
Has thanked: 2 times
Been thanked: 3 times
Post by altalake »
'04 XC70 170,000km - I completed the PCV service (FCP Euro suggests 3 1/2 hours - about 10% of what it took me) but with the oil sump return still plugged. Fired it up and it runs fine on initial start at 1,500rpm but with a dash warning "Reduced Engine Performance" and, once it drops down to idle, runs terribly. Haven't tried driving it yet.
VIDA shows 5 faults: BCM-0004, BCM-1000, BCM-0115, ECM-91B7 Throttle valve - Faulty signal, ECM-130A Air Leakage intake
I suspect it's the last two that are relevant. Checked hoses and pipes and connectors and everything looks good.
The car ran fine with no dash warnings despite a fully clogged PCV oil trap before I dug into it.
Any ideas of what I might have missed or messed up?
Thanks.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 603 times
Post by vtl »
You introduced an air leak. Get it smoked. I have this one, it's sort of expensive, but, unlike my cheap DIY attempts, it actually worked.: www.amazon.com/AutoLine-Pro-Automotive- ... B07JVT1NG2
altalake
Post by altalake »
Thanks for the quick reply and good suggestion but it turned out to be something simpler. The electrical connector to the ETM - the one that's so hard to release - was not properly seated. All good now with no relevant error codes.
altalake
Post by altalake »
Follow up a year later.......
I did drive it with the plugged oil return passage for over 1,000km before getting the oil passage cleaned by a shop. No oil blow by and not even one drop of oil on the splash pan after a year.
Has thanked: 1834 times
Been thanked: 1709 times
Thanks for taking the time to update this thread.
Neil
