P80 Speaker test box - Guidance required!
Has thanked: 2199 times
Been thanked: 1851 times
Well all the un-tested head units are tested and are fully operational. I have a bunch more that I know work but were not fully tested but do power up and play CD's. The cassette function was not tested as at the time I did not think I still had any!
I also tested all the speakers I had. Pretty good outcome with only 1 bad one. It works but barely. I am assuming it has 'popped' as we used to call it 40 years ago. Probably could be repaired but not worth the effort. I do have 2 that will need the cones glued. Small puncture holes. I will do this with watered down wood glue which seems to be the recommended method. Holes are small, and the speakers work fine, but I don't want them to degrade.
Testing the C70 speakers were a real pain! Every speaker has a different connector and the wiring diagram I have is wrong in several areas in terms of wires changing color along the path, and 2 speakers having the same wire colors?? I had to make up flying leads for every speaker to test them. All were good!
Today is tidy up day as I have a mess on my workbench and need the space to repair my R dash mounts. It has been a somewhat challenging project but very satisfying to get it working. Now have to find time to get homes for all this stuff!! :lol: :lol:
Nikitawen
Year and Model: 1990
Post by Nikitawen »
Getting them into the passenger door has me foxed. No matter what I try I cant find the internal side of the hole the wires go .through
Anyone have any tips? Hopefully not necessary to remove the glove box?
Sorry, I missed this question. What car are you asking about and where are you trying to feed the wires from and to?
The wires on a P80 run through a harness that can be unscrewed at the hinge area. All the door wiring including the speaker wiring runs through that harness on each door.
