Heat Help
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Re: Heat Help
Post by vtl »
Based on the symptoms, thermostat or heater core would be the immediate suspects.
olds60
Year and Model: 2007 s60
Post by olds60 »
So the car has 130k miles, thermostat (oem) was replaced at 100k at dealer. After all this I decided to replace the thermostat and that seems to have been the problem! Does this seem normal an oem thermostat failing after only 30k?
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
olds60 wrote: 30 Dec 2023, 19:00 So the car has 130k miles, thermostat (oem) was replaced at 100k at dealer. After all this I decided to replace the thermostat and that seems to have been the problem! Does this seem normal an oem thermostat failing after only 30k?
you can test the old one with a thermometer and hot water.
