2001 V70 2.4T Failed Massachusetts inspection for steering play
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
chris11211
Year and Model: 2006 s60 2.5T
Has thanked: 7 times
Been thanked: 29 times
Re: 2001 V70 2.4T Failed Massachusetts inspection for steering play
Post by chris11211 »
abscate wrote: 28 Jan 2024, 04:37 I’m not quite so concerned. There is a lot of structural redundance built into a rack. Are you sure the wheel is being held tight while that play is being exercised? If I push pull on my tie rods on a P80 the steering wheel moves, that’s isn’t play
So my s60 has steering rack play for years. Apparently no one can align the car with the steering wheel straight, but if it's "aligned" to the computer then the car does drive straight but with a crooked wheel. Should i really bother changing it? Too much for a cheap car.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
chris11211 wrote: 29 Jan 2024, 13:13 So my s60 has steering rack play for years. Apparently no one can align the car with the steering wheel straight, but if it's "aligned" to the computer then the car does drive straight but with a crooked wheel. Should i really bother changing it? Too much for a cheap car.
Yeah, that's why I went ahead and invested into a manual 4WD alignment rack (SharkEye). 15 minutes and it drives straight, with steering wheel straight.
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
It seems like the P2's had a near 100% failure rate on the steering rack. Is this common across other manufacturers?
04s60 2.4
04xc70 2.5t
Has thanked: 1505 times
Been thanked: 3818 times
850 LPT wrote: 29 Jan 2024, 08:28 After reading all this I am getting a little concerned about my older daughter. She lives in Boston (loves it), and based on my recommendation she just bought a super clean 03' V70 2.4T in December. A one owner car, purchased and serviced at Boston Village Volvo for most of it's life.
The car failed inspection due to worn tie rods. No big deal, I replaced them, and she just had the alignment done. Now she has to get the inspection done again.
I so hope this doesn't become a financial nightmare for her with these tough inspections. Are these good for one year only?
Thanks, Dirk
I kept Caitlin’s car registered in NY while she worked in MA and extended the inspection one year. Out of state plates aren’t too much of a hassle in MA. Let it run the course , and remember Dad shop is only two hours away!
vtl
Post by vtl »
br0dy519 wrote: 29 Jan 2024, 19:43 It seems like the P2's had a near 100% failure rate on the steering rack. Is this common across other manufacturers?
I think all of them eventually wear steering racks out.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Hum. Time to find an early, well kept P2 parts car for my future use?
vtl
Post by vtl »
volvolugnut wrote: 30 Jan 2024, 07:50 Hum. Time to find an early, well kept P2 parts car for my future use?
Makes no sense.
I have half of XC70 leftovers from swapping the guts into the donor body. Doubt will ever use them. Had even more, but threw out most of if while we had a rented dumpster, after keeping it all in garage for 3 or 4 years.
Heck, I still have NEW parts for 2002 V70 and 2016 XC60 I sold long ago.
You never know what happens next in a year or two. Maybe it will be totaled by a smartphone zombie. Maybe you'll get weary of it falling apart constantly (it happens to all P2s I've owned or knew of). Maybe your interests shift 180 degrees, and a small road-only passenger car does not fit your new needs and wants.
Best you can do is save cash for your future needs, whatever they happen to be.
vtl, see my fleet list below. I tend to have parts cars for all my vehicles. Volvos are rare in my local salvage yards when I need something. I also tend to keep my fleet on the road a decade or more and then park them. I also have lots of parking space.
The economics may not be sound, but it is my method. This will not work very well for most people.
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
Update: I took the car down to our local trusted garage (not Volvo-specific, but generally trusted by everyone in the neighborhood for being honest, competent, and no-nonsense) to get a diagnosis and estimate for repairs. Their diagnosis was that the play is coming from within the steering rack and it needed to be replaced. Their estimate was $1,350.16: $568.23 for the part, $11.36 for shop supplies, $600 for 5 hours labor, $119.95 for alignment, $14.40 for hazmat, $36.22 tax.
I really don't feel like this is a job I want to do myself. I have done other long, complicated jobs, but most of them have not been under the car. It's also not an ideal time of year for working outdoors, considering I would need to get it fixed in the next 60 days.
Now I need to do a cost/benefit analysis of paying for the repair on this car versus ditching it and getting another used car. Overall it is a great car to drive and it runs relatively well for its age and for the amount of things I know should be fixed but haven't. I know it's going to need a new set of tires soon, and I also just discovered that the driver's side CV axle needs to be replaced. There's also some electrical gremlins that make the engine run rough in cold weather. I just don't know what else might fail in the next few years.
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
vtl
Post by vtl »
It takes less than 5 hours to DIY steering rack w/o car lift, but, anyways, this is not a dependable car in 2024.
