Leaking transmission sump on 2000 S70
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 97 times
- Been thanked: 42 times
While I had this apart I figured I would test the pins on the large connector on top of the trans. All of the tests were in spec except pins 16 and 17. These are for the turbine speed sensor (engine speed sensor). Suppose to be 300-600 ohms. I read around 19M ohms. I tested the one on my 93 850 and it reads around 400 ohms. Is it possible it could be bad and I wouldn't know it? Volvo parts app calls part number 9496115. Mine has a blue dot label on it at the sensor end.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
jmartin919
Just to wrap this up. The turbine speed sensor (engine speed sensor) on this year vehicle is a different part from previous years (don't know the break). The sensor has a very high resistance (19 meg ohms on mine) and is best tested with the multimeter in diode mode. Should read around 1 in one direction and infinite when probes are swapped. The Duraprene gasket worked great (thanks chrafael). I used Permatex 81180 on both sides of the gasket but probably didn't need to. Replaced the torx bolts with hex head bolts (the ones that are used on the hood hinges are the right size) and lock washers. No more leaks!
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
jmartin919
Follow up: trans sump cover leaking again, dripping off temp sensor. Checked the lowest cover bolt and it was rather easy to tighten so I snugged it up pretty good. Did the same on the 3 or 4 others that I could easily get to. If I had to do it again using the gasket I would increase the torque on the pan bolts to more like 15-20 lbs instead of 10 to compress the gasket.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- 1557 Views
Last post by erikv11
- 1395 Views
Last post by zimbodel
- 1192 Views
Last post by theWIFES_S70
- 2888 Views
Last post by siboyslim
- 1380 Views
Last post by crussell83
