Poor quality valves Topic is solved
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Re: Poor quality valves
Post by Sveedy »
Well it kind of seems like having different weight valves would change the effective spring rate, but again, I'm no expert.
I'm going to grab a small scale today and do a little valve weighing.
1999 V70 GLT
Sveedy
Post by Sveedy »
Even though it doesn't make much sense, the new Skandix valve weighs apx. 2.8g more than the stock valves, even with the choke down on the stem.
Results for those following along :
Cyl #1
Valve A - 40.7g
B - 40.5g
Cyl #2
A - burnt
B - 41g
Cyl #3
A - 41g
B - 40.8g
Cyl #4
A - 40.9g
B - 41g
Cyl #5
A - 40.7g
B - 40.8g
New Skandix - 43.6g
1999 V70 GLT
Sveedy
Post by Sveedy »
Could the difference in weight between the old and new be due to different amounts of sodium in the stems ?
1999 V70 GLT
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 999 times
Post by volvolugnut »
Sveedy wrote: 31 Jul 2025, 16:30 Could the difference in weight between the old and new be due to different amounts of sodium in the stems ?
That was one of my thoughts. Also, the necked area might be a joint were the valve was rejoined after filling with sodium.
Has thanked: 1497 times
Been thanked: 3810 times
I’m not sure these new valves are sodium filled.
Spring frequency is SQRT (k/m) where m is valve plus spring mass , so the frequency of oscillation won’t change much. I don’t think an extra 2g mass will amount to much extra force on the spring , has anyone measured k on valve springs?
I am going to swag it at 1000 N/cm or so
Sveedy
Post by Sveedy »
So I ordered two valves from ProParts Sweden. They have the proper dish and stems, but weigh 4g more than stock.
Based on weight, I'm better off with the Skandix, even with the stepped stem. Kind of surprised that the manufactures miss the stock weight by so much. If your copying something, then in this case, I'd think size and weight would be both be considered.
However they are consistent within manufacture from what I've seen.
1999 V70 GLT
abscate wrote: 01 Aug 2025, 03:13 I’m not sure these new valves are sodium filled.
If we had the k value for the strings, cam lift and duration specs, and I had the will to dig into all the dynamics calculations, an answer could be found if 2 or 4 grams added spring mass will make a difference. Most likely it would only float the valves at max RPM if too much valve mass.
Calculation not likely to happen for all above reasons.
Someone who has a spring off needs to measure its length, put 4 liters of water on it , measure compressed length , and report both numbers
An Apple experiences a gravitational force of 1 Newton, at the core of the issue
So let’s do the math.
The valves open about 1cm = 0.01 meter
To compress the spring 1cm thus takes mag (F)= k mag(x) = 1000 N/m * 1E-2m = 10N
The 40g valve has to be accelerated from rest to open at 200 times a second (50E-3 seconds) roughly so
F = mA= .040kg * 1e-2m/50E-3)^2 = 4E-2 * 1E-2/25E-6)=4E-4/25E-6 =1/6 E2= 16 Newtons
That’s not a huge force for forged steel working parts of the engine amd valve train
Skandix now showing that valves and valve stem seal kit will be back in stock end of September.
Sveedy
Post by Sveedy »
Well what my research has shown so far, is that I'd probably be fine with different weight valves if it was a NA engine.
And if I didn't run it at high rpm's.
And if it didn't have all of the performance upgrades that it has.
And if I wore a tweed sport jacket when I drove it.
And if that jacket had leather elbow patches.
And if I smoked a pipe (but I do :wink: )
Well then apparently I'd be just fine.
So I'm in a holding pattern right now. It's either replace all of the exhaust valves with aftermarket valves, which will all be the same, or try for used stock ones. Mr. Spinner ( Robert DIY ) is now looking into getting a couple of stock ones for me, so fingers crossed. If anyone can come up with them, he can.
1999 V70 GLT
