S70 Turbo Contactless ETM Needed Topic is solved
ericmci
Year and Model: 1999 S70 GLT
Has thanked: 73 times
Been thanked: 15 times
Post by ericmci »
I will- anything in particular I should pay attention to with the rules?
Also- tips on removing it?
I imagine there will be more space than my car to install, as most salvage yard cars already have some things removed.
I will bring any tool I think I might need and some PB Blaster of course.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
So between this thread and the ETM section, I'm a bit more lost than before. Does the progression go from white label to yellow label and then back to white again ? In the ETM section, the yellow label is mentioned as the upgraded one. I'm currently running on a yellow, but maybe the newer white is better ?
1999 V70 GLT
Sveedy
Post by Sveedy »
I think you will find it easy enough to remove. 4 bolts, a hose and a connector. Installing might be a little bit trickier, but totally doable.
1999 V70 GLT
Has thanked: 1609 times
Been thanked: 4063 times
It’s tucked under a bunch of stuff on a 1999, it’s tough access. Pull the radiator shroud out to get more room. It mounts vertically as I remember so the bolts face down
Hers the history Sveedy
Original ETB made by Magneti Marelli
Two contact wipers, lasts about 150k miles then starts coding errors when the wiper readings don’t match. 10k miles after first errors it will start going into limp mode, very low power , 20 mph max
Yellow label ETB also M-M and is still contact type. Better software? They don’t seem to die like the white labels
Xmodex takes either one and puts on non-contact sensors
Finally , Volvo released a white label, non M-M contactless one that’s the one you want. They seem to be on eBay for $150-200
ericmci
Post by ericmci »
Do you have a link for the non M-M contactless white label one on eBay
I can't find anything that is turbo not 400 dollars and isn't m&m
I looked quickly a week ago, you do have to put trust that the seller is telling you what car it came from.
IMPORTANT FOR JUNKYARD HARVEST
the stock wiring for the ETM runs behind the starter and is trapped by the right side starter mount. Most of us remove that and throw it away , it’s redundant and Volvo discontinued it in2002.
Don’t cut the ETM wires thinking you can solder them, there are CaNBUS data lines that don’t like Janky-ness
(Insert picture of startermount)
The 12mm block bolt is tough to remove in Northeast climates. You have to remove it and two m6 nuts on the right side of the starter motor
Sveedy
Post by Sveedy »
So maybe removing the intake is the easiest way to go....
1999 V70 GLT
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
abscate wrote: 15 Oct 2025, 19:02 It’s tucked under a bunch of stuff on a 1999, it’s tough access. Pull the radiator shroud out to get more room. It mounts vertically as I remember so the bolts face down
Those also fail as the magnet in the shaft bulges and scrapes the windings.
Sveedy
Post by Sveedy »
Well what I found at the JY today, was a 2001 V70XC. I was hoping to find a white label, but the car had a yellow. The newer '04XC had a ETM that looked totally different, so when exactly did the use the white label ?
1999 V70 GLT
Has thanked: 2196 times
Been thanked: 1850 times
Only 01 and 02 P2's used the MM ETM like the 99-02? P80's. Not sure if with the change in P2's in 03 models if the 03-04 C70 P80 changed too or not.
Even the 02 date may be chassis related as the 02 XC70 I helped with had a later P2 TB (it is a dumb unit unlike the MM unit).
