Rear Camshaft Seal Replacement.
This topic is in the MVS Volvo Repair Database » Project: Volvo S70 Rear Camshaft Seal Replacement
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
The timing belt should hold the cams in place. So maybe you already have the belt removed?
If the timing belt is removed, hopefully the crank is on the mark. If you keep the crank on the mark, then you can rotate the cams all you want just make sure to put them back in time before you put the belt back on. In other words, do what it takes to get the bolt off (shouldn't take much) then put the cam back.
However if you are asking about the 2005 V70 mentioned in your profile, this is the wrong place to ask and my answer could be wrong. I would go post the question over in the forum for those newer cars http://new.volvocars.com/ownersdocs/199 ... 70_102.htm
SCP74
Year and Model: 2002 v70xc
Has thanked: 1 time
Post by SCP74 »
How does the trigger wheel tighten? My vvt cam is moving as I torque down the trigger wheel.
