Best year for an 850
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Yeah, on the 850's they pull out of the armrest.
- Year and Model: Many Volvos
- Been thanked: 76 times
The cup holders didn't come as standard equipment until '96. There are some optional early model armrests with cup holders for the earlier models but they are cheesy at best. The early model replacement armrest has two cup holders that have maybe 1/2" of depth and if you get on the brakes the whole console gets drowned if you have a McDonalds cup in it. I have also had trouble with mine sliding out under braking - it is a bad design.
The later model cup holders are a bit better but not much, they at least have more depth. Check the repair database, I think LukeTrash modified a later model armrest to fit into a '95.
The cup holder arm rests typically go for around $40.00 on eBay.
I installed a hitch on my 850 and use it all the time. I just make sure to not haul too much. I read that the 850 wasn't meant to really tow anything. Is that true? I haul a single place jet ski trailer and utility trailer. Also, is there a filter that can be changed on the automatic trans?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Any kind of car can tow something. Except maybe a Prius... I towed a 3,000-lb uhaul trailer with my Honda Accord. It could barely accelerate at all, and was dragging the ground, but it did it!
The tow rating for an 850 is 3300 pounds, but I'd say keep it under 2500 and it'd be better for your car - a jet ski/small trailer are well within that limit
. When towing something heavy, put the car down into 3 on big hills and take off gradually so it doesn't keep shifting a lot.
There is no transmission filter on an 850, which is why a flush is good to do every so often.
'98 S70 T5
2016 Chevy Cruze Premier
meine39
- Year and Model: 1995 850 GLT Wagon
FWD vehicles tend to have much lower towing capacities than comparable RWD or AWD vehicles - not sure about all the physics of it all, but I believe it has something to do with weight of the towed item on the back of a FWD car unloading the front drive wheels and diminishing towing capability. I'm betting someone here on MVS who routinely tows a large boat or camper could describe it much better.
1995 855 GLT 190K NA Auto
1998 BMW 528im 137K
2000 Toyota Camry 78K
2010 GMC Acadia 57K
1998 BMW 528im 137K
2010 GMC Acadia 57K
jblackburn
That's exactly what it is. In a FWD car, the traction comes from having the engine over the front wheels. Load up the rear of the car, and you pull the weight towards that end of the car and thus lose traction.
For comparison, my sister's Escape and my dad's Liberty have similar engines, curb weights, etc. The Jeep is RWD/4WD whereas the Escape is FWD. The Escape is rated to tow ~3000 pounds, whereas the Jeep can handle 5000.
It was also much better at towing a U-Haul than my Honda was, and has the brakes for it too
'98 S70 T5
- 2830 Views
Last post by TheMrFailz
- 2107 Views
Last post by oragex
- 1091 Views
Last post by 850forum
- 8183 Views
- 740 Views
Last post by combatkarl
