Drivers side door stop
FASTR1
Year and Model: s70 2000
Post by FASTR1 »
no way
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I have not had the "A" pillar issue, but my driver's side door check did go south again. I replaced the part last weekend in about 1/2 hr. The actual door check in mine had broken in half with the lower portion of the plate containing the studs that accept the 10MM nuts on the door having broken clean off. In fact, the lower portion of the plate fell down into the inside of the door when I was removing the door check. I also noticed that the metal in the door near where the check bolts up was split through. Looked awfully thin for a potential stress point.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
FASTR1
Post by FASTR1 »
I can say that with the proper tools and mig welder that this repair is not all that difficult, however I did my newly purchased s70's and the way Volvo has done things is great again, to pull the door to gain access is so simple, a tiny torx screw to release the lock on the multiwire plug for the door, a quarter turn of the plug disconnects it, then two external torx bolts that hold the door to the hinge pins, then the door catch bolts if it is not already broken, mine was and a friend and the door lifts right off, heavy though. I taped up all areas of concern for spark and fire damage used other material to shield the dash area, pulled the rubber door seals loose. and had at it. The metal is thin and if there are gaps it is more difficult to do, and cleaning the paint is a must for a proper repair. Using a hand held sandblaster is the easiest and have done this many times on Jeep Cherokees for door hinges that tear. Once the weld is complete any pin holes left I use body seam sealer or grey rtv to smooth coat, then paint to match with spray touch up. On my car unless I alert you to it , is almost not recognizable.
Not a job for someone that does not have any prior welding skills!
Faust
Year and Model: xc70 2008
Has thanked: 31 times
Been thanked: 10 times
Post by Faust »
Someplace in this thread I posted pictures of welding it up with a mig. With two guys (to aid lifting and refitting) it took about 1/2 an hour.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
lookforjoe
Year and Model: 1991 743
Has thanked: 2 times
Been thanked: 4 times
Post by lookforjoe »
I've seen this issue many times.
It's amazing how many responders didn't READ the OP's post & just suggested replacing the door stop.
Removing the entire door is very simple, as already described. Welding the seam is a permanent repair. Normal welding precautions are all that is required to prevent wiring damage.
I would however like to see pics of the nut/bolt repair from the aussie mentioned. If I can find them, I will add them to this thread.
