Brake failure message came on as well as the ABS light
Re: Brake failure message came on as 4well as the ABS light
I just put my 06 s60 in the volvo shop they told me 200 bucks for a check and i guess we will go from there ill keep u updated they will get to it tomarrow
- Has thanked: 1505 times
- Been thanked: 3818 times
You can buy a good AUTEL scanner for about 200 which will read codes for the rest of your life, including ABS and SRS codes
- Has thanked: 17 times
- Been thanked: 35 times
Bcm? I found this on Youtube from a search-
A bit humorous but not so much when you live with this crap and it's ongoing without finding a solution.
Basically, this is an electrical issue- typically a ground wire disconnected or shorting- it might be the BCM or it could be related to grounding somewhere in the system that the BCM is attached to. I would go for another indie repair shop and let them know everything that has been said to you by Volvo but tell them that you don't really suspect it's the BCM, but an electrical grounding/shorting issue instead. See where they take it from there. Btw, I'm not sure if you can just replace a BCM from another car or not- if you can, it's probably typical Volvo stuff that requires it being "married" to your car by way of a software download. However, since you've dealt with XeMODeX already, it might be worth giving them a call and asking them this question.
Sorry- someone in this thread had- Their ad is at the top of MVS. Here is their website: http://xemodex.com/us/
The brake failure message is telling you codes have been set. These codes don't triggered 'service engine soon' message ( the P2 version of check engine light)Frank65 wrote:It was not showing any codes or check engine light
Well fuck 800 bucks later and 200 diagnostics from Volvo how about that rebuilt BCM from the site above and it was not the BCM a guy said its the ccm or something like that under the dash ..i can tell u he said the bcm plug theres 2 blue wires one 16g wire and one about 18g tested it and the 18g blue wire gos to the ccm and its not getting power 12v he said i said to him put a jumper wire with a 15amp fuse to my cig outlit fuse panel and it worked every thing started working again ..guess im asking is this ok lol
Fixing electrical problems like this is poor workmanship. The fault of lost power has to be traced to root cause or else more trouble is sure to come. A mechanic who can detect a missing voltage then doesn't know how to proceed shouldn't work on these cars, or most any post 1996 car.
- 876 Views
Last post by [email protected]
- 3362 Views
Last post by Wilse
