Almost 40 mpg!
Almost 40MPG in a Volvo S70!
I get 21 mpg in the city and 29 mpg on the highway...
Current Volvos:
2004 C70 HPT (wife)
2002 S40 1.9T (daughter)
2001 V70 XC (daughter)
1999 V70 GLT (now dead)
1998 V70 GLT (son)
The other car: 2003 Saab 9-3 SE Convertible (mine)
2004 C70 HPT (wife)
1998 V70 GLT (son)
My mileage sucks balls. 15mpg, with new plugs, wires, rotor, cap, fluid changes, flushed tranny, tires inflated to 36 psi..... I drive aggressively but not constantly. Anyone can tell me what I should check next? Thanks.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
How many miles? What kind of driving? Running A/C?My mileage sucks balls. 15mpg, with new plugs, wires, rotor, cap, fluid changes, flushed tranny, tires inflated to 36 psi..... I drive aggressively but not constantly. Anyone can tell me what I should check next? Thanks.
Stoplight to stoplight driving, running A/C...that's probably about right. City mileage is just awful on these things. First gear is incredibly tall, and it's heavy.
Have you ever replaced your O2 sensor? Cleaned the MAF sensor? Changed your air filter?
'98 S70 T5
2016 Chevy Cruze Premier
I was getting 10-12mpg city, but I live in Brooklyn and drive very aggressively. 98 S70 base auto trans. I made the following changes since I got the car a year ago, new struts, shocks, control arms, axles, brakes and a front end alignment. New plugs, wires, rotor, cap and air filter. Alignment and axles were done a week ago.jt74 wrote:My mileage sucks balls. 15mpg, with new plugs, wires, rotor, cap, fluid changes, flushed tranny, tires inflated to 36 psi..... I drive aggressively but not constantly. Anyone can tell me what I should check next? Thanks.
On my current tank of gas i used regular fuel but tossed in a bottle of octane boost and lucas fuel treatment I got on sale. Did not change driving habits and am now around 20mpg.
I noticed the biggest change after I had the axles and front end alignment done. Not sure if the octane boost is really helping as I used to use 93.5 octane from Sunoco, but since I got it on sale it was much cheaper to spend $2 on higher octane gas in a bottle rather than the 40 cents per gallon x 16 gallons for the 93.5.
So if your suspension is all good, it might be worth checking out the alignment. Just my 1/50th of a dollar on the issue.
Yeah, a lot of city driving and run the AC 50% of the time. Not more than 250 miles per week. I get some highway but it is mostly sitting on a ten mile stretch of parking lot during rush hour. Boo.
O2 sensors are next on my list, air filter is brand new, and I will need to get the MAF cleaned. Suspension is almost done, just need to get some new spring seats ( IPD HD, thanks J. xD) and then I can do the alignment. I only run 92 or better. Hopefully after I do these things I can at least get it to 20mpg+. Thanks for the tips fellas.
Woot!!! I'm not a "new member" anymore. Yeah!!!!
jblackburn
1000+ miles of driving on my trip to the Outer Banks this weekend. It was beautiful - if you're in the non-automobile forum, I'll post up pictures at some point, so be sure to drop in!
34.5 mpg from here to VA beach this weekend (over 300 miles) - 65-75 mph, interstate driving, windows down. I was getting 37-39 for the first 100 miles or so.
27 mpg driving around the islands in NC (windows/AC sometimes); lots of stoplights and terrible drivers.
30 mpg even from VA Beach back to here last night (windows down again) - 65 mph most of the way, but on a different highway.
I think my car knows what I've been thinking about - and it's trying to compete with little-car MPG. And honestly, after all that driving with it, I'm not so sure I could ever want another car!
'98 S70 T5
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Well done!
I think part of getting better MPG is simple wanting better MPG. But your car isn't going down without a fight!
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
jblackburn
Keep in mind that increasing tire pressures takes a bit of rubber off the road from what the car is designed for! I never do that because it does make handling squirrely and wears out tires faster. If you buy into it, possibly inflating them with pure nitrogen may increase your MPG a little bit. I already chew through a set of tires about once a year, so I'm not about to make them last any less long.
'98 S70 T5
FlyingVolvo
The nitrogen thing is a gimmick. I get it only because Costco gives it to me for free, but I'd never pay for it. I figure with all highway driving (with heavy loads I might add), the tires will be fine with the added pressure. I've gotten very normal wear out of them so far, so I'm not too worried...
(You saying something probably means my tires are gonna blow up on my next drive!)
2023 V60 T8 PE
2023 V60 T8 PE
- 2005 Views
Last post by woc2
- 839 Views
Last post by draser
- 835 Views
Last post by dux02v70
- 855 Views
Last post by jcdillin
- 1652 Views
Last post by kaneelschep
