I decided to modify the procedure a little though and instead of adding dowels between the spring and thermostat, I did it by installing a fat o-ring around the thermostat body, so that the thermostat still works, but defers to ALL COLD at a much cooler temperature.
See the little black ring here? Take it off and stick a big o-ring in here, or two if they are thinner. Slide the black ring back over the thermostat and re-install. If it's almost there but not quite, another smaller o-ring can be installed around the recessed 'neck' of the thermostat where the pin comes out. Notice how it's shut to cold now!
Throwing it in the freezer, the flap moved over for partial hot at around +1'c and quickly moved back to all cold after five minutes of being out and at room temperature. Much better I'm sure!!
Test drive - this has made an instant +2mpg efficiency difference and it has also as predicted helped in gear changes. This may be the final part of the puzzle as I really think changes may be about as smooth as they are ever going to get now; keeping in mind this is a 16 year old box which has covered 130K Miles and has only just recently had the fluid changed!
I could go insane now and start renewing engine mounts in the quest for a perfect gear-change, but I really think it's 'good enough' at this stage.
The other job I did today (and I'm not sure this will have a bearing, but mention for completeness) was swap out the manifold to exhaust gasket, which was a complete buttock of a job made all the worse by the crappy nuts and bolts Volvo supply for this now!
Chris...
