850, lots of boost + how to go even faster?
trophytaker308
- Year and Model: 1995 850t turbo
i guess some guys now how to get 500hp and have a fwd race car..
1995 850t turbo,siver with black leahter interior (perfect),, 118000 miles .second owner.9 out of a 10...!
kcjones
- Year and Model: 1997 855 GLT 200k :)
I think some guys know how to overboost and eat tires.
The money/time he spent to get there is probably 10 times overkill. Get to stage 0, do ECU, intercooler lines, a quality intake kit, and full exhaust.
If you do it yourself, It will cost about $2000 and you'll have plenty of race car to go around.
If you really want to spend some money, you can upgrade the turbo, intake and exhaust manifolds. But that alone will eat your 3 grand.
Then you get into a world of high flow injectors, dual fuel pumps, and broken transmissions.
trophytaker308
show so what should i do to get 300hp to be safe,what would you guys suggest.i have more than 3000 to spend.
Juan62
- Year and Model: S70 T-5M 1998
- Been thanked: 2 times
Trophytaker;
Go to www.ipdusa.com and put your car information in there. You will be focusing on Hi-Performance parts, take a look to get some ideas. Now, there are many others who sell performance parts for Volvo. I highly suggest that you get your car to STAGE ZERO, then upgrade. IPD has a complete Stage I, II, and III kits for around what you are willing to spend, but you can also shop around. www.vivaperformance.com, www.eurosporttuning.ca, www.snabb.us and others on www.volvospeed.com
Take your time, and get all the relating parts to do a specific purpose first, then move on to the next upgrade. You are going to have to consider upgrading your suspension and braking too. Just do your homework first, and try to do some of the installing yourself. This helps you learn more about the product and self-confidence when you do it. I look forward seeing some of your pictures here in the near future. Good Luck with your endeavors!
98 S70 T5-M Brick for life
trophytaker308
i have checked the car over 100 times, no check engine light and the motor sounds perfect.so what do you mean by starting at 0?
- Has thanked: 2866 times
- Been thanked: 1332 times
Our Stage 0 page here at MVS.
trophytaker308
ok here it what is going on the car
1.stage1 ecu
2.ferrita sport exhaust kit
3.turbo air inlet kit
4.ipd short ram intake kit.dont know if i should get that one or the cci one???
5.big bore turbo intake kit fron snabbs.comes with a 960 tb and a few extras...
thats all im doing to the motor,should be safe and aroung 290hp im guessing,im also going to do all new pvc hose and anything else that goes with it.
shhould this be safe for my car and i dont hot rode it,i drive it normally,actually i babie it,just like to have the extra power there when its needed,plus its a hobbie of mine...chime in if you guys think this will be ok.i dont want to over do it to mess my motor or tranns up...thanks for all the tips.
1.stage1 ecu
Juan62
Okay. Assuming that you read the STAGE ZERO with understanding and your car is at that level. Now also consider upgrading the TCV to HD TCV, change your Compress By-Pass Valve (CBV) from IPD or VivaPerformance, spark plug to 8mm, and a NEW PCV (Flam Trap) Kit from IPD or FCP Groton.
trophytaker308
thatys all on the list when i insall all the other parts,also will be all brand new hoses.
UncleBoost
- Year and Model: 855 R, 1996
I was just reading this... Read the entire article to get familiar with what you have...The best source of knowledge is reading. Research... Try this for starters : Modifying FWD Turbos
