2.4t VVT adjustment right or a problem
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
jimmy57
Been thanked: 320 times
Re: 2.4t VVT adjustment right or a problem
Post by jimmy57 »
Yes, it is what they parent metal bearing, just machined into the casting with no bearing insert.
You should drop the oil pan and clean the pickup tube for oil pump and replace seals on the pickup tube and the other tube that goes from filter housing over to oil cooler outlet.
It would be a great idea to take off the oil feed line from front side of block to turbo and make sure it is clean in case the prior repair didn't get that cleaned out. If you have time the pickup tube and turbo feed pipe would be best cleaned by cleaning vat soaking at a machine shop or parts store with machine shop. Their cleaning tank chemicals will get that sludged oil out. Cleaning with brake cleaner spray and .22 rifle cleaner round brush is also good.
You may have to order those o rings for the pan, pickup, oil cooler feed, and turbo pipe copper washers.
I bet you'll find the oil pan could use vat soaking.
lwilliam22
Year and Model: 2001 v70xc
Post by lwilliam22 »
Great. I've already done the oil pan, and since seeing how bad it was I've been worried about everything else. I guess with good reason. I think I might check turbo lines. Since a impeller was found in exhaust! Still waiting on my seals to come in
lwilliam22
I've cleaned cam oil ports and now resembled. Start cart car and clank / rattling again problem still there. I havent checked buying I'd bet it's off again. I've had enough I'm pulling engine and tearing it dont something is astray
lwilliam22
Well motor is out. I now have a question. The flexplate moves , the center part on flexplate where bolts go through has 2 plates that look to be plugged welded together. But mine I can hold that center part and rotate the outer, which would be the plate and cranksensor relutor wheel. So I figure that explains why my timing was getting off ? The crank wasn't reading right and vvt would try to adjust and throw itself off. Explains why one trip drove good and then light a light switch it an awful
jimmy57
Post by jimmy57 »
I'm shocked it wasn't making a whole lot of racket.
lwilliam22
Well it would rattle periodically , and knock. I took it apart at the middle support washers ( flexplate) and the center around the bolt ring was broke all the way around And the back had a gouge on the back like a bolt had hit it, so I wonder if when the tranny was done they dropped one That's when the problem started
lwilliam22
I'm done! I pulled engine out and flexplate was busted allowing the outer ring to spin which threw off crank sensor reading. I got it all back together and ca seems to run great. Thanks for help along the way
revsource
Year and Model: 2002
Post by revsource »
Same problem, 2.4T fails when I give it gas, starts great but as soon as I put a load on the engine it bogs down. I had changed my timing belt and tension.
On Alldata shows the timing set up is different for variable valve timing units and or with engines with different serial numbers? I set mine up not realizing that and am wondering if that maybe my issues.
see alldata picture, hope this helps, I haven't reset mine yet just using another car.
timing vvt vs non.JPG (104.39 KiB) Viewed 1574 times
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
ask your question in a new thread, faster responses that waking up an old thread.
By the way, you'll need the cam timing lock tool to realign everything correctly. You probably have the timing off a couple of teeth because you did not realign the CVVT gear
zerdas
Year and Model: v70 2004
Post by zerdas »
You can watch this tutorial. It mainly deals with timing belt replacement and CVVT setup for volvo engine. I hope it will help.
