1998 S70 stalling no codes?
marcusheard
- Year and Model: S70 turbo, 1998
The fuel pressure at my fuel rail is reading 36.5 psi . I'm wondering if that is too low. I wondering where can I check the ohms resistance of my fuel pump, and the acceptable ohms range of the pump? The pump cost~$100 and the fuel pressure regulator also cost ~$100, so I would like to rule one out with my volt meter if I can. i have already replaced the fuel filter. What do you think?
marcusheard
My pump is reading 1.9 ohms resistance at the pump's plug. I believe that it should read (1- 1.5 ohms resistance). What do you think?
I have turned off all ODBII codes by replacing my MAF and IAC (idle air control valve); still stalling so I'm leaning towards fuel pump or fuel regulator. I'm reading 36.5psi at my fuel rail.
marcusheard
After replacing my fuel pump, fuel filter, IAC, and MAF - my problem ended up being my ICM (ignition control module). I just replaced that part last year (aftermarket - only cost $25). Luckily I had a spare lying in the garage - hooked it up and she came to life again. Stalling without any codes - tuff fix. If it would not have started at all then I would have guessed ignition system - but it started fine but would not stay running. Can't believe that it took me so long to find my faulty ICM. I'll test drive tomorrow, and hope that I'm right.
- Has thanked: 312 times
- Been thanked: 818 times
Do you mean you swapped the ECU (computer)?
marcusheard
No, the coil and (I think the other part on the coil bracket is the resistor - I'm not certain). For $25 got the entire bracket assembly last year. I can post a pic later.
- 7728 Views
Last post by enriquepr21
- 1834 Views
Last post by Samtara1
- 4256 Views
Last post by eric v70
- 19 Replies
- 2698 Views
Last post by bmdubya1198
- 12 Replies
- 2575 Views
Last post by gvsu4msu
