Volvo 850 DIY: Front Flexible Brake Line Replacement
This topic is in the MVS Volvo Repair Database » Volvo 850, S70, V70, XC70 Front Brake Line Replacement
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
jreed wrote:Front Flex Brake Line Replacement – Volvo 850
ImageIf you put the wrenches on at the right rotation, you can squeeze them together with one hand and avoid twisting the hard line.
I am preparing to work on our 2001 V70XC Jason.
Would you rephrase the highlighted text for clarity?
TIA!
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Or even put a screwdriver perpendicularly between the two wrenches at their free extremity and 'twist' the screwdriver.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Thanks for asking. It's been a while since I did the brake line job but my memory is that I could put the wrenches on the fittings so that the loosening of the flare nut was accomplished by squeezing the handles of the two wrenches into alignment in the palm of my hand. The same effect would occur if you use two hands but it seemed easier to do it with one hand. The main point is to keep firm pressure on the fixed nut and apply the turning force mainly to the flare nut. Be sure to have applied penetrating fluid well in advance.
Hope this helps clarify... if it's still murky let me know and I'll try again.
xHeart
Post by xHeart »
oragex wrote:Or even put a screwdriver perpendicularly between the two wrenches at their free extremity and 'twist' the screwdriver.
Like a lever...turning the 11mm flare nut against the 14mm fixed hose connector. Very interesting!
Thank you Jason and Oragex, it is clearer.
