1996 854 ECC top vent problems
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Re: 1996 854 ECC Resolution
Post by Klausc »
No more blinking lights!!!!
It was not an electrical problem as suggested by the multiple error codes. All 4 damper motors were maxed out in their position or the vent was jammed.
Today I removed all 4 motors, one at a time, placed the motor in the middle of the travel range after cleaning out the grease. Then put them back on the air unit making sure the baffles were also in the middle of their range of travel.
I put the ECC in Mode 4 and keyed in 9-9-9, selected Auto for the vent position, put the fan in a run position and started the engine. After taking a 2 mile run above 20mph and letting the car sit with the key in position I for two minutes, the lights were out on restart - NO CODES.
Someone else went through the ECC before, a screw was missing on the passenger vent motor.
Klaus
Free2drive!
Year and Model: 2007 XC90
Post by Free2drive! »
Great news! Really glad you solved it.
Matt
