94 850 turbo No engagement of auto transmission
- Year and Model: Many Volvos
- Been thanked: 76 times
You seem to have been overlooked. You need to download the factory service manual and then see the file named Auto Trans Diagnosis.pdf for explanations of the codes and further testing procedures. The manual is here:
https://www.matthewsvolvosite.com/downlo ... vo_850.zip
The big one is the 1-2-2 which is an open circuit on the S1 shift solenoid. Code 3-2-5 doesn't appear as a valid code. The other codes, 2-3-2 is a bad or missing VSS signal and 2-3-1 is a erratic throttle position signal. Those can be dealt with after the car is moving again if they are real.
- 21 Replies
- 4170 Views
Last post by zupta82
- 2196 Views
Last post by koolhandluke
- 596 Views
- 1775 Views
Last post by mf70
- 884 Views
Last post by robin_740
