I had a broken hose on the roll-over valve that was giving a P0455 on my '97 855. I replaced the hose and the problem was solved.
The P0410 (Secondary Air System) code may be due to a seized air injection pump, disconnected hose or a SAS valve on the exhaust manifold that is stuck open.
1998 S70 GLT car stalled MVSOLVED, IAC cleaning
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
terris1859
- Year and Model: 1998 volvo s70 glt
will the p0410 code give me problems that will keep my car from running or can I wait about a week or so before fixing it after I fix the rotted off hose.
- jreed
My experience was that the P0410 code posed no problems in performance or driveability other than turning on the Check Engine Light. The secondary air system reduces tailpipe emissions during warm up and sometimes at idle.
terris1859
good, after we get the vaccum hose fixed maybe I can start driving it again and leave the old gas hog truck parked.
terris1859
another quick question though,the p0500 code -vehicle speed sensor A- is this code why my speedometer doesn't work?
- jreed
Sounds good. The P03xx codes (p0300-random/multiple cylinder misfire detected, p0302- cylinder 2 misfire detected, p0304- cylinder 4 misfire detected) should get attention as soon as you can because misfires can lead to unburned fuel getting into the catalytic converter, which can lead to expensive damage.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Abs/tracs light on?terris1859 wrote:another quick question though,the p0500 code -vehicle speed sensor A- is this code why my speedometer doesn't work?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
terris1859
abs light is on
- misha
Abs/tracs module is bad and needs to be re-soldered.
Pm Matty Moo about abs module or search the abs/tracs module re-soldering thread here on the forum for more info.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Volvo Manic
- Year and Model: V70,2000
misha wrote:Abs/tracs module is bad and needs to be re-soldered.
I had an ABS and TRACS light on after every start. I fixed it though with a new switch behind the ignition switch cylinder.
I arrived there because after starting the engine the ABS and TRACS lights went out after jiggling the key. And doing that was the only way to release the transmission lock to get it out of park.
So just another thing to look for on those lights.
It was at least the second switch replacement on this car. I don't know the history of the car with respect to the weight of the keys used in it by the original owner.
- 849 Views
Last post by a73s
- 670 Views
Last post by turtle1615
- 14 Replies
- 2447 Views
- 11 Replies
- 3266 Views
Last post by jonesg
- 39 Replies
- 8761 Views
Last post by DARK_BLU
