How about silicone di-electric grease...aka Super Lubejimmy57 wrote:Chrysler ignition boxes,,,,,,,,,,can be sealed with cheap clear silicone sealer .
I didn't run a string line but I've rebuilt many engines before, checked and alined the marks several times over the last 6 months, and am pretty confident they are right. I appreciate your interest but I'm now searching for other causes.93Regina wrote:Did you follow these instructionsMr Sabetodo wrote:Everyone I've talked with seems to think that it's a fault of alignment.
You ran a string line, yes?
No
Check rotor's position when done, yes?
yes
nope, one of them (with a notch) has a hole for the gear alignment pin to fit into the harmonic balance. They can't be switched.lummert wrote:You may have those timing belt guide washers switched. I'm thinking that the washer with the timing mark doesn't go on last. But I don't know for sure if it would change the location of the timing mark.Mr Sabetodo wrote:I don't have a plug with threads that match so I lined up the timing mark w/ TDC on the cover and looked inside with my cheap boroscope from amazon. it appears to be 1/2 tooth off but that's perspective because I couldn't see straight down because the distributor drive wheel is in the way. Everyone I've talked with seems to think that it's a fault of alignment. I'm 99.9% sure that it isn't. This engine has 3 computers and several sensors that will put it into limp-home mode. I think Its one of them and I've replaced all but one (under the glovebox) because it looked new. The replacements were from ebay so it's possible they're bad too. sadly I don't know which one & I'd rather not replace them all again. I suspect the one on the right wheel well because it controls timing. Is there a way to test it?
I highly doubt it, but you might go to local salvage yard, and find another dizzy, and Chrysler ignition unit.Mr Sabetodo wrote:is it possible the pickup inside the distributor could be rotated?
It only takes a few minutes to bring up on TDC, pull distributor cap, and inform us where it (rotor cap) is pointing.Mr Sabetodo wrote:alined the marks several times over the last 6 months,
