97 855R Just bought it and I love it..except a few issues
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
Re: 97 855R Just bought it and I love it..except a few issue
She's beautiful...the front cover of the Haynes repair manual has your same exact model 855R in red.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 2 times
Both--the rear calipers are located at the rear of the rotors so both is correct. Just make sure when installing the half shims that the arrow points up for both pads since they face each other.koffinb wrote:So I am confused as to what I have been reading..should the arrows on the shims be pointing up or the direction of wheel rotation?
I did a full brake job on our S70 a few months ago, but prior to, it was not noisy with the L shaped Volvo shims in there. But just put rotors and pads on the rear of my wagon yesterday. It was screaming with worn down pads and using those full rectangle Teflon shims (which were worn bright naturally). So use the stainless half (L shaped) shims. They are by far the best.
Both cars had Volvo OEM pads, so I can affirm to jreed that the shims make the difference.
Beautiful 855.
Those are the ones I used. Thanks.dosbricks wrote:Both--the rear calipers are located at the rear of the rotors so both is correct. Just make sure when installing the half shims that the arrow points up for both pads since they face each other.koffinb wrote:So I am confused as to what I have been reading..should the arrows on the shims be pointing up or the direction of wheel rotation?
Beautiful 855.
1997 855R-Completely Bone Stock..for now
- jreed
- Has thanked: 352 times
- Been thanked: 192 times
Thanks for the feedback... good to know. I will keep on using the stainless steel half-shims the next time I need to replace the rear pads. Thanks again
So yesterday this code came up and I thought it was due to a small exhaust leak I had about 2 inches behind the cat...so I welded it back together and cleared the code. After driving a while the CEL came back on so I went back in to check the specific code and it was the same one again. P0133. Front o2 sensor?
What are some of the most common weak suspension points on these cars? Looking at the records I don't see much in terms of suspension work apart from sway bar links, a control arm and delta anchorage links (whatever those are)
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
koffinb wrote:What are some of the most common weak suspension points on these cars? Looking at the records I don't see much in terms of suspension work apart from sway bar links, a control arm and delta anchorage links (whatever those are)
At that age & mileage,
spring seats
strut bearing plates
Struts
shocks
sway bar bushings
ball joints (control arms)
ties rods (inner & outer)
basically, everything
'00 S70, '04 S60 and the never ending quest for Stage Zero
Yeah..I was afraid of that answer lolRussB wrote:koffinb wrote:What are some of the most common weak suspension points on these cars? Looking at the records I don't see much in terms of suspension work apart from sway bar links, a control arm and delta anchorage links (whatever those are)
spring seats
Struts
shocks
sway bar bushings
- 1736 Views
- 1940 Views
Last post by SuperHerman
