1999 S80 T6 Overheating problem revisited
Oly_850
- Year and Model: 2000 S80 T6
Idont recall the size, but be very careful, these bolts seem to strip out fairly easily, and at hard enough to get to I the first place. I used a slim 1/4 inch drive with the shortest length Torx bit combo I could find.(253) 582-2408
'12 Ford Focus SE - Black Pearl
Owned:
'00 Volvo S80 T6 - Maroon
'98 Volvo V70 - Red
'90 Volvo 740 GLE - (sold, too far gone)
'96 Volvo 850 GLT - (totaled) :\
Want - A6 Quattro, XC90, C303
Owned:
'98 Volvo V70 - Red
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Yes, they like getting stuck in there (steel bolts in aluminum); you can drip some penetrating oil and give it overnight to help break loose but be sure to wipe it off carefully before disassembly - you don't want that penetrant to get into the cooling system.
Use some anti-seize on assembly.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
Alright, just came back from the job half way done. First the good stuff: the spark plugs look fine, there is no unusual deposits on them, they appear a schoolbook example of good combustion.
Now the bad part: whoever put the spark plugs in probably didn't use anti-seize compound, but even that wouldn't be a problem if he didn't screw in plug #3 like a madman. After running engine for ~20 minutes, I removed five spark plugs with some effort, but #3 wouldn't give. Finally I used a piece of pipe to get me some leverage and the damn crappy Chinese spark plug socket tool snapped.
As an additional bonus, the compression tester thread adapter decided to stay in #4 and I could not get it out without long nose pliers. Tomorrow I will get the pliers and put some Loctite on the thread on the other side which will hopefully keep it in place.
Unfortunately I didn't have anyone to help me out, so I just cranked the engine 6-7 turns which should be more than enough. I would prefer to have someone check the gauge while I am cranking, but it wasn't possible now.
Anyway, here are the results (drum roll...)
Cylinder #1:
Cylinder #2:
Cylinder #4:
If I am not mistaken, these readings are quite poor, bordering with horrible. Over the weekend I will remove the remaining spark plug, warm up the engine and repeat the test after pouring a bit of oil in the chamber and see it the value changes.
To be continued....
Cylinder #1:
Cylinder #2:
Cylinder #4:
To be continued....
- regent
Here is my one-man compression test workaround:
Since my arms are not telescoping/articulating, I deploy my red-neck remote-start switch (one hand with a jumper at the starter solenoid coil, eyes on the gage, my other hand is busy holding the beer
And I make sure I'm not injecting any fuel (pull the injectors' supply fuse)
Your first readings appear to be indicative of a lawn mower/oil washdown syndrome, no?
2015 BMW 335i
2015 BMW 335i
Nice trick, I will give it a go.regent wrote:Here is my one-man compression test workaround:
Since my arms are not telescoping/articulating, I deploy my red-neck remote-start switch (one hand with a jumper at the starter solenoid coil, eyes on the gage, my other hand is busy holding the beer![]()
Now you made me google it. Feels good to know there are still new things to learn even at this age.regent wrote:And I make sure I'm not injecting any fuel (pull the injectors' supply fuse)
I did pull out the fuse for the fuel pump. I am wondering about these readings, if they were correct I should have felt a loos in power, but from what I can tell the engine pulls very nicely.
- regent
Even with the pump disabled while cranking, the injectors are still firing and fuel is draining nicely onto the walls of the bores (so long as there is some residual pressure in the rail). That's why I prefer cutting off power to the injectors.
Since your engine feels strong, I was beginning to wonder why you would suspect low compression...
2015 BMW 335i
2015 BMW 335i
See subject - I am trying to figure out if the head gasket is blown. I know the compression test will not be conclusive, but it is fairly easy to do so why not. Also, I may be wrong as I never had a chance to feel how a brand new T6 engine is supposed to work....but this seems decent enough as it is.regent wrote:Even with the pump disabled while cranking, the injectors are still firing and fuel is draining nicely onto the walls of the bores (so long as there is some residual pressure in the rail). That's why I prefer cutting off power to the injectors.
- regent
Understood; let's think positive and hope your gasket is fine
2015 BMW 335i
2015 BMW 335i
- 26 Replies
- 6499 Views
Last post by bmdubya1198
- 2341 Views
Last post by Sommerfeldt
- 11 Replies
- 2753 Views
Last post by MrAl
- 14 Replies
- 1834 Views
Last post by MrAl
- 1800 Views
Last post by Kfbtaz
