94 850 Turbo. I bought the car with 280xxx miles.mecheng wrote: That is quite a bit of mileage! Original engine, head, headgasket, tranny? Which engine?
At 333,000 miles, I took out the original engine with the non-original transmission out so I can prepare the car to put in a rebuilt engine/manual trans/upgraded turbo in the car. 1.5 year later, the head porter was still dragging his feet to finish the head, and I was tired of waiting so I bought a running parts car with 160k engine/trans and put them in my car. The 333k engine still ran fine, so is the transmission, but transmission was seeping ATF and the engine's compression # wasn't the greatest, it made sense to buy a running parts car and use them instead.
I still have the 333k engine/trans but I highly doubt I'll be using them again.
For $2,400? That's way too much for a used transmission, in my opinion. No need to change both axles if they're not broke now. Fluid is 6-8 qt of ATF. For $2,400, I'd want a rebuild transmission.The shop here has a 1 year warranty on a transmission with 150k miles on it, the warranty also covers 70% of labor, so if it does need to be taken out I won't be out on all the labor either. So between a 1 year warranty on a transmission, with 70% of labor under that warranty, 2 new axles, fluid, and everything, we are looking at around 2,400 dollars.
You can always use your S70 in town and rent a car to travel long distance if you worry about reliability.
