1997 855 GLT Cranks but won't start
RunningMike
Year and Model: 855 glt 1997
Post by RunningMike »
That's what the work shop told me 1,5 years ago when the same error accurred. Could you tell me what the right way is, given that I have +12V on pin 2 in the cam shaft sensors connector? (as in the video I linked to).
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
FLXC90 wrote:OP says couldn't get it to fire on ether, are you sure you have spark?
What about this....do you have a spark?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
RunningMike
Yes, as I posted in the first post it sparks on all five cylinders. And later I posted that I discovered it sparks 60-70 degrees before zero. I tried the start fluid straight into the cylinders and the enginge coffed a bit once the plugs where back, but with that advance timing ignition I guess not even ether is going to make it run.
misha
Post by misha »
So...you are saying that timing is wrong.
On these cars...timing tolerance is up to 3 teeth.Everything after that pistons would hit valves and that would be game over.
With tolerance up to 3 teeth,engine will start and run but it will run badly and idle badly.
So...it can't be timing.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I don't have any answers, just trying to clarify ...
OP has posted it 3 times now: he is not talking about mechanical timing (when the valves open and close relative to piston stroke), he is talking about the timing of the spark. Spark timing can certainly be wrong without any disturbance of mechanical timing.
Are the plug wires attached in the correct order? That little metal thing under the rotor is in the correct orientation?
screwdriver
Year and Model: 96 volvo 850t
Post by screwdriver »
no fire with ether = no spark. possibly a relay or fuse.
Post by erikv11 »
:roll:
OP has stated a couple times now, the car has spark on all 5 cylinders, but the spark is out of time with the compression stroke.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Exactly Erik, ether was to identify strictly whether it was a fuel problem, since that was being postulated at start of the thread. That was ruled out and OP stated timing advance 60 degrees before TDC and we know ignition timing is in the ECU. Therefore, it appears to be a programming problem/fault in the ECU. Could the Crank and cam position sensors play into it with a bad input? Or are they simply a failsafe for the interference motor?
Current Volvos:
FLXC90
Post by FLXC90 »
Since cams run at different speed than the crank, could the CPS base and plate be installed 180 out? would that throw it off by about 90 degrees?
Current Volvos:
FLXC90
Post by FLXC90 »
Scratch that last one, car would not have been running, DUH! Ok but if the sensor failed, it would screw up signal to ECU. It may test statically, but not work properly. Without reading codes, can't call it good. Mike, do you have another cam sensor to test with?
Current Volvos:
