An RMS leak is likely over time however once you deal with the PCV the chances of an RMS failure diminishes greatly. It wouldn't be a bad idea to change BOTH rear cam seals including the one behind the cam sensor.
Once you have a read of how easy the timing belt replacement is you'll want to replace the 2 front seals as well, but that's later
