90 240 DL wagon only starts with starting fluid when cold.
bobbycgolf
- Year and Model: 1990 240 DL wagon
Well cant hear or feel the inline pump working at all. Jumped it from fuse 4-6 and nothing. Relay seems to be working,so i ordered a pump,filter,and check valve along with new balljoints. Will install when i get the and should have the problem solved.
bobbycgolf
When i jump fuses 4-6 the pump runs? Turn on the key pump doesnt run ? Have new Fuel pump relay new fuel pump new fuses thru whole fuse box new fuel filter,why isnt the fuel pump triggered on with the key being on?
bobbycgolf
Pulling my hair out.
Replaced fuel pump relay,fuel pump,fuel filter, all fuses, cleaned fuse box very well. When i turn the key on the fuel pump does not turn on... When i jump fuse 4 to 6 the pump runs... When i jump 30 to 87/2 the pump runs. Car will start/run/drive right now cause i primed the pump,but it will not in the morning. Why will the key not turn on the pump?
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Answer: ECU Fuel Pump Control Circuit Repairbobbycgolf wrote:Why will the key not turn on the pump?
bobbycgolf
Man i think i either try a used ECU and if that doesnt work I guess I have an awesome parts car. I do not believe I can reconstruct an ECU.
bobbycgolf
Is that what your suggesting an ecu or ?
bobbycgolf
I was thinking the same thing last night. Push button style.
bobbycgolf
Is the fuel pump relay normally noisy?
- 1757 Views
Last post by doublebug
- 147 Views
Last post by cn90
- 3111 Views
Last post by nucci480
- 4688 Views
Last post by Roger M
- 1538 Views
Last post by volvolugnut
